EMERGENCY!! On the quest for VTEC!
Old Jun 16, 2003 | 10:43 AM
turbotime's Avatar
Default EMERGENCY!! On the quest for VTEC!
Ok, I just got the y8 head onto the block, a few loos ends to tie down first, need help. First of all in plug one I have the 3 pin connector that is also attached to the mass airflow sensor, is this correct? Items 2 and 4(on back of intake looks same as 2) I know one of them connects to the FPR, but as for the other? 3 I thought PCV but I dont think it is. Please help, got the new head in the car but im dead stopped until I can figure these out.
Thanks
Dan
Old Jun 16, 2003 | 10:58 AM
nerdsports's Avatar
Default Re: EMERGENCY!! On the quest for VTEC! (turbotime)
#4 is for the FPR... plug#1 is the MAP sensor, however, the TPS has the same plug shape so be careful not to confuse them. #3 is for the PCV. not sure what #2 and #5 are for..... if im giving wrong info, correct me. but that should be right.......
Old Jun 16, 2003 | 11:17 AM
Ekizzle's Avatar
Default Re: EMERGENCY!! On the quest for VTEC! (nerdsports)
#4 is not the FPR, the FPR is the yellow thing !
Old Jun 16, 2003 | 11:35 AM
ScrapinSi's Avatar
#1 Map Sensor
#2. FPR vaccuum line
#3. EVAP Vaccuum Line
#4. Cruise Control Vaccuum line
#5. EVAP
Old Jun 16, 2003 | 11:37 AM
Ekizzle's Avatar
Default Re: EMERGENCY!! On the quest for VTEC! (ScrapinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi &raquo;</TD></TR><TR><TD CLASS="quote">#1 Map Sensor
#5. EVAP</TD></TR></TABLE>
Old Jun 16, 2003 | 11:42 AM
turbotime's Avatar
#3 EVAP, so does that go to the PCV, or to the valve cover?
Old Jun 16, 2003 | 01:13 PM
BoostedSi's Avatar
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">#3 EVAP, so does that go to the PCV, or to the valve cover?
goes to the pcv
Old Jun 16, 2003 | 03:57 PM
nerdsports's Avatar
Default Re: (BoostedSi)
tried to help..... apparently it didnt work so well....
Charlie Moua
Apr 13, 2012 08:24 PM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
jdmeg9
Jul 15, 2005 01:08 PM
musclefella
Apr 15, 2004 09:12 AM
