Fuel line replacement fun
Old Jun 16, 2003 | 09:06 AM
jaxle's Avatar
Default Fuel line replacement fun (56k warning, 2 large photos)
Hey all, this is my first post here and im hopin maybe some of you can help me out with replacing my fuel line.
The problem is is that its a one piece steel line that goes from the gas tank to the fuel filter and its gonna be hard to get in place because of this bracket and stuff covering it that is in the way. Heres a pic: http://www.auctionpix.co.uk/users/cph269929.jpg and a different angle: http://www.auctionpix.co.uk/users/ess269930.jpg
You must copy and paste these url's into your address bar for it to work.
As you can see there is this plastic covering with a metal bracket covering it. This bracket is bolted or something to the car but i am not able to get off the nut because it is rounded or something, no socket will fit it. This is why i am planning on grinding the bolt down and drilling it out unless anyone can tell me how to get it out the right way. I measured where it should be and i pulled up the carpet and i can not find anyway to access the bolts head. Now once I get this plastic covering off it will still be hard to remove and replace the fuel line because what looks like suspension components are in the way. Can anyone tell me if it will be safe to unbolt these? The car is supported by jack stands so there is no weight on the wheels.
Thanks for your time.
Modified by jaxle at 8:49 PM 6/16/2003
Old Jun 16, 2003 | 11:49 AM
jaxle's Avatar
Default Re: Fuel line replacement fun (jaxle)
bump :/
Old Jun 16, 2003 | 06:27 PM
jaxle's Avatar
bump.:/
Old Jun 16, 2003 | 06:36 PM
AllMotorHB's Avatar
Default Re: (jaxle)
your pictures don't work
Old Jun 16, 2003 | 06:47 PM
jaxle's Avatar
If you read my whole post it says
I just checked them, they do work when u copy and paste, atleast forme..
Old Jun 16, 2003 | 08:13 PM
GripFactoR's Avatar
Default Re: (jaxle)
dont grind too much...
sparks + fuel = kaboom.
Old Jun 17, 2003 | 06:16 PM
jaxle's Avatar
i know, but im not gonna be drilling thru the fuel line.
Old Jun 24, 2003 | 09:54 AM
jaxle's Avatar
Ok i got all the brackets off but it is still way to cramped to pull out the old fuel line and putting in the new one. i think that if i unbolt those components i ahve highlighted in green here: http://www.auctionpix.co.uk/users/cph269929.jpg
NOTE: you MUST copy and paste this link into the address bar for it to work!
Can anyone identify what that is and if it is safe to unbolt with the car on jackstands? i think it is part of the suspension. If a different angle would help please say so. thanks.
Old Jun 24, 2003 | 03:34 PM
Blown90hatcH's Avatar
Default Re: (jaxle)
That fuel line is such a pain. It was a pain getting it off and I was just cutting it everywhere. The problem bend is where it goes over the rear cross member. There is a nasty bend that goes up,down, up that makes it almost impossible to remove without dropping the cross member.
Old Jun 24, 2003 | 03:35 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (Blown90hatcH)
Wow, blown90...that's a lotta posts
Old Jun 24, 2003 | 07:49 PM
jaxle's Avatar
Yea i took bolt cutters to the bitch. i figured out that it was my lower control arm bushing clamp dealie. i dont know why i couldnt figure it out before i found it both in my helms and haynes manuals, i guess im just dumb sumtimes haha. Anyways whats the cross member? can u hlep me out and tell me what to unbolt? tomorrow im unbolting the lower control arm and try to fit it thru.
btw, that one long plastic bracket thing, i hacked, choppd, and basically destroyed it haha. its 10$ for replacement and im guesing its to cut down on vibration, did u put that back on when u replaced yur fuel line?
ps. my grammar sucks... hope u can read my sentence structure, im a lil tired
Old Jun 25, 2003 | 06:04 AM
jaxle's Avatar
bump :/ cant pm blown90 cos im trial
Old Jun 25, 2003 | 06:32 AM
Default Re: (jaxle)
It was easy for me when I put it back in because I was using -8 braided line. IT was able to make the bends over the crossmember. The cross member is the black beam looking member that is underneath the intake manifold/goes right to left...from looking underneath, the lines go over it. I am not 100% sure this is the way to do it, but I am almost positive. IF you have the helms for your car, I couldnt find where it gives instructions about removal, but it shows a pic of the cross member and what bolts to remove to get it out.
Old Jun 25, 2003 | 07:28 PM
jaxle's Avatar
alright thanks a ton man
Old Jun 26, 2003 | 08:56 AM
jaxle's Avatar
hmm what page did u find the info about the cross member in your helms? i cant figure out where it is.
Old Jun 26, 2003 | 05:56 PM
Default Re: (jaxle)
It is on...20-119
Old Jun 26, 2003 | 06:16 PM
jaxle's Avatar
thx again, i'd pm ya but yea...trial rules :/
Old Jun 26, 2003 | 06:19 PM
Default Re: (jaxle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaxle &raquo;</TD></TR><TR><TD CLASS="quote">thx again, i'd pm ya but yea...trial rules :/</TD></TR></TABLE>
ITs cool man. I just check my recent posts.
Old Jun 27, 2003 | 03:33 PM
jaxle's Avatar
sorry to bring the thread up again but if anyone else has the pleasure of replacing their fuel line on a 5th gen like mine i thot this info would be useful.
blown your helms must be for a different gen b/c mine (5th gen) has nothing about the cross member nor does it have a page 20-119. I found what you are probably talking about, i guess they are calling it sumthing different in mine, the sub-frame. thats on page 20-95 for you 5th gen helms owners. I am now in the process of taking this off, thank god i have an impact wrench . you have to disconnect the control arms, steering gear, and some other bolts holding it up, pretty self explanitory, good luck to anyone tackling this in the future
Old Jun 27, 2003 | 03:59 PM
Default Re: (jaxle)
Yeah, mine is the 00 manual.
hoytheld
May 16, 2014 02:12 PM
Anderson413
Sep 22, 2011 08:23 AM
edifyexistence
Jun 13, 2011 09:26 AM
nate-the-great
Jan 20, 2007 04:31 PM
justinCO
Aug 6, 2002 12:22 PM
