Need help quick (hurry need and answer)
Old Jun 16, 2003 | 07:42 AM
88civic4d's Avatar
Default Need help quick (hurry need and answer)
alright i have tried using 10w 30 and 40 but no use to stop valves so which oil should i use now 5w 20 or 50w20 im going on a road trip and i need to know so i can change my oil before i go.
Old Jun 16, 2003 | 10:04 AM
88civic4d's Avatar
Default Re: Need help quick (88civic4d)
bump
Old Jun 16, 2003 | 10:08 AM
tilt's Avatar
that makes no sense. "but no use to stop valves" -- what are you trying to say here.
Old Jun 16, 2003 | 10:21 AM
civickiller's Avatar
Default Re: Need help quick (tilt)
i think hes talking about valve knocking. use higher octane gas, or adjust yoru vavle back to stock specs. after a while your rocker arm to valve clearence will be off from stock cause the valve chattering, just have them adjusted back to stock
Old Jun 16, 2003 | 10:26 AM
blah13's Avatar
Default Re: Need help quick (civickiller)
Yeah sounds like valve tick, get them adjusted, high octane wont help, I doubt hes getting detonation. Avg cost for valve adjustment at dealership = $70-80
Old Jun 16, 2003 | 11:55 AM
smokinvtecCRX18's Avatar
From: yea thats right i got a flowmaster and it owns you, Oklahoma, usa
Default Re: Need help quick (blah13)
not to steal your thread but does anybody know how to do a proper valve adjustment, a few of my friends can adjust valves but im not sure if they are 100% sure on how to do it? just curious
Old Jun 16, 2003 | 12:53 PM
Default Re: Need help quick (smokinvtecCRX18)
get a feeler gauge, and set it to wahtever inche it suppose to be, then loosen the valves and stick the feeler gauge in there, adjust it so the feeler gauge can move around in there not easy but with alittle resistance, then tighten and yoru all good
Old Jun 16, 2003 | 01:04 PM
litlekikr's Avatar
you could try using an oil additive. I've tried BG RF7 (I think) as well as Hyper Lube and it quited the valves down quite a bit. I used these AFTER i had already adjusted my valves so i new they were in spec. You could try using a thicker oil, maybe 20w50. Just a suggestion.
alfre1183
Sep 22, 2017 10:08 AM
GSRVTEC1
Oct 31, 2005 01:19 PM
cornhusker
Sep 20, 2003 03:37 PM
TurbothisLS
Feb 13, 2002 10:48 AM
GreenMachine
Jan 14, 2002 04:01 PM
