Body Kit: Urethane vs. Fiberglass
Old Jun 16, 2003 | 07:05 AM
BIntegra99's Avatar
Default Body Kit: Urethane vs. Fiberglass
I've noticed that the extreme body kit is fairly popular amongst the readers\posters of this forums. I was wondering if most people got it in Urethane or fiberglass..and how crucial it is one way or the other ?
Old Jun 16, 2003 | 07:16 AM
wuhungsixxx's Avatar
New User
Default Re: Body Kit: Urethane vs. Fiberglass (BIntegra99)
dont get fiberglass...it WILL crack on you...
Old Jun 16, 2003 | 10:18 AM
IntEGNYC's Avatar
Default Re: Body Kit: Urethane vs. Fiberglass (evan2)
For a daily use car, Id recommend urethane bumpers.
The earlier poster makes some good points. however, there are other factors to be aware of. Bumper repair is a moot point given the severity of repair required. If you have a severe impact, the bumpers will need to be replaced, period. In a minor impact, the fiberglass will crack and shatter. The urethane bumper may crease or bend. Both are repairable but require different methods of repair.
Urethane isnt stronger as it is more resiliant and durable.
Generally for low lying bumpers, flex is normally added as it takes abuse from the road. For this aspect, using Urethane or Fiberglass should not be any different. This should be a measure of the quality of work of your autobody shop.
good luck
aJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evan2 &raquo;</TD></TR><TR><TD CLASS="quote">depends on what you want and how much you want to spend
heres some things to ponder
fiberglass
cheaper, lighter, cheaper to paint, easy to fix
if the kit doesnt fit right you can modify glass really easy and really cheap
ureathane,
stronger, most expensive, heavier, if it doesnt fit when you buy it have fun making it fit
costs more to paint because you have to add flex agents to the paint
yea it might not break but if you hit it hard enough you are going to mess up paint regardless.. hello to spider webs
its really all about what you want..</TD></TR></TABLE>
Old Jun 16, 2003 | 10:36 AM
B16A2-EM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIntegra99 &raquo;</TD></TR><TR><TD CLASS="quote">I've noticed that the extreme body kit is fairly popular amongst the readers\posters of this forums.</TD></TR></TABLE>
Are you sure your on the right forum?
Rob Simon
Jul 8, 2017 05:31 PM
saab900
Paint and Body
Oct 18, 2009 07:38 PM
h22lude317
Dec 30, 2008 07:03 PM
crxrider07
Aug 31, 2008 01:01 PM
kcmd
Honda S2000
11
Feb 28, 2007 07:53 AM
