WTB: stock Integra catback...OBD-1 to OBD-2 stuff
ok, need to make this thing pass CA emission asap....
the car is a 94 teg LS with 98 LS motor, but converted to OBD-1 (motor should be OBD-2)...it has no cat, w/ 2.5" piping and an ES oval muffler....
so I need a stock cat back (cat, b-pipe, and muffler if possible)...
also need a stock OBD-2 wiring harness? whatever is needed to make this thing stock. Thanks!
how much are you looking to get for your 98 GSR catback?
interested in a testpipe, 2.5" b-pipe and ES Oval muffler? I can pay instead, but want to ask jic...LMK. Thanks
Sorry, I did some reading and realized that I will need an LS catback, the GSR/ITR won't work on a LS apparently. Thanks anyway
So...I prefer an OBD-2 LS catback, but may settle for a OBD-1 LS catback...thanks everyone.
I will get a hold of you..I am going to get the catback for now, try and fool them into passing it as a 94 (since the body is 94)....
otherwise, I will PM ya. Thanks!
well good luck and just let me know! but i think some of them could and know the difference between the motor (like valve cover, but you can always say you just change it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C uR eX »</TD></TR><TR><TD CLASS="quote">well good luck and just let me know! but i think some of them could and know the difference between the motor (like valve cover, but you can always say you just change it)</TD></TR></TABLE>
yeah, up here they don't know ****...so unless they check the #'s, then I think I might get lucky...I'll see.
Just so I know, what are you charging for the OBD-2 LS wiring harness? LMK, thanks.
