Mis-Shift...need help??
Hey guys, just need a quick answer with something, I was doing about 120km/h in 5th, and don't ask me how, but I was on the phone and wasn't paying attention and wanted to go to 4th to pass some guy, however, I accidentally shifted to second, and I let the clutch off for a second, enough for the revs to go to almost 10 on the tach, however, I realized the mistake and I hit the clutch again immediatly, and put it into 4th. I was so worried, but the car seemed totally fine after, it idled normally, and I even pushed it like raced it a couple of times, hitting v-tec, and there was no problem, she drove fine. My buddy said do a valve adjustment just incase, and I probably will, but it drives good, so should I be worried, like would I have noticed something wrong instantly or would it develop over time, like would she drive fine and I woulda still have fucked something up??
Happens to a lot of people...if your idle is good, you're probably ok.
Do a quick check on the valves anyway, and perform any necessary adjustments to be safe. You're not hearing any ticking are you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChiNoS »</TD></TR><TR><TD CLASS="quote">Ticking when?? Be more specific??</TD></TR></TABLE>
Very loud ticking at idle... Much louder then normal, you will know if you hear it.
I would suggest doing a compression check to be absolutely sure nothing came together. If your compression checks out Ok then your good to go.
Nope, no ticking, I took it to Acura however, and the technician came out for a drive with me, popped the hood, checked it out and I raced it with him in the car, and he said she sounds good, just do the regular oil changes (synthetic) and the 96,000 km service and I should be fine. He said I was ******* lucky!! hehe
