My Dyno and VAFC settings from Bay Area Dyno Day
Old Jun 15, 2003 | 03:24 PM
Art Vandeleigh's Avatar
Default My Dyno and VAFC settings from Bay Area Dyno Day
Thanks Austin for setting up another great dyno day. And most importantly for setting up the VAFC!!!!! I owe you a for sure....oh wait shouldnt you be providing that???
(edit)
My mods:
DC JDM
T1r 2.5" exhaust
carsound 94066
comptech ice box
vafc
Anyway here is the plot:
I was a little dissapointed that I didnt get in the mid 170's but o well. After Austin changed the x-over, I gained about 20whp max. I was mainly concerned with the A/F. I have a carsound and i really didnt want to spend another $200 for a replacement because I was running too rich....
So here are my settings, thanks to Austin:
(Fuel)
<U>Lvt</U>
3000-&gt;(-4)
4000-&gt;(-4)
5000-&gt;(0)
<U>Hvt</U>
4500-&gt;(+2)
5000-&gt;(+3)
5500-&gt;(+2)
6000-&gt;(-3)
7000-&gt;(-5)
8000-&gt;(-13)
9000-&gt;(-14)
Vtec x-over:
L-&gt;H:4700
H-&gt;L:4500
V/T unmt:
Hi&lt;&lt;L:+4
Lo&lt;&lt;H:0
Throttle:
Lo:10%
Hi:50%
As you can see, from the first run, I was running a bit rich up top. But the rest of the A/F looked pretty good to me. After the fuel changes, I leaned up quite a bit. I am really happy with the tq numbers...and the gains from 4.7-6.
But from looking at this graph is there anything that you dyno tuners think I could try?? Maybe play with the fuel some more?? Is it too lean?? any help would be great!!!
Thanks again Austin!! and DSR is a great place. They will see more busines from me in the future!!
Modified by Art Vandeleigh at 12:35 AM 6/16/2003
Old Jun 15, 2003 | 04:00 PM
acuracing's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (Art Vandeleigh)
Nice numbers Jerry, mine are right behind yours, and I'm more stock than you! . It was cool meeting you yesterday.
Old Jun 15, 2003 | 04:06 PM
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (acuracing)
Hey man!!! You do have a sweet hybrid!!
More stock....you are pretty much all stock. I pretty envious!!!
Too bad about your buddy with the pickup. I hope he gets it all cleared up soon. If your ever down my way drop me line!!
Old Jun 15, 2003 | 05:52 PM
jdmspoonitr's Avatar
Nice numbers. Your numbers are actually better than mine, but last time I was on 17's so we are in the same range. When did you get the header? And have your exhaust issues been fixed?
4500 Vtec engagement is SWEET!!!
Old Jun 15, 2003 | 06:03 PM
SurferX's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (jdmspoonitr)
Cool deal, glad everything worked good. The VAFC is always nice for picking up that midrange.
Old Jun 15, 2003 | 06:07 PM
CHROMETR's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (SurferX)
Dude you should totally get spinning chrome rims it makes it go faster i dynoed atleast 50 pounds of torque hgher when i put mine on. Also you should swap the head with a d15 and use the LS intake cam, i did it on mine and if i can fix the hole in my fuel map ill pull 9s
Old Jun 15, 2003 | 07:12 PM
GokuSSJ4's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (CHROMETR)
nice #'s i will be picking up my vafc reall soon
Old Jun 15, 2003 | 08:39 PM
Tweakmeister's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHROMETR &raquo;</TD></TR><TR><TD CLASS="quote">Dude you should totally get spinning chrome rims it makes it go faster i dynoed atleast 50 pounds of torque hgher when i put mine on. Also you should swap the head with a d15 and use the LS intake cam, i did it on mine and if i can fix the hole in my fuel map ill pull 9s</TD></TR></TABLE>
why would you even waste your time writing that
Old Jun 15, 2003 | 11:05 PM
Unsung's Avatar
Wow those are some decent numbers. Definitely makes you realize how far off the butt-dyno can be. Why god, why can't there be a decent tuner in my area.
Old Jun 16, 2003 | 08:11 AM
Austin's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (Unsung EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsung EM1 &raquo;</TD></TR><TR><TD CLASS="quote">Wow those are some decent numbers. Definitely makes you realize how far off the butt-dyno can be. Why god, why can't there be a decent tuner in my area. </TD></TR></TABLE>
Tuner...hell, I'm not a tuner, I'm just a hack It just takes a little knowledge of the product, and how to read the dyno plot. The VAFC is a very simple piece of electronics, and doesn't take a whole lot to tune/play with.
Austin
Old Jun 16, 2003 | 10:04 AM
Nick248's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (Austin)
I've been somewhat confused regarding the V/T unmt %. I've asked many tuners to elaborate and explain this parameter percentage but no one seems have an answer.
I see that the V/T unmt was changed to +4. What does that mean? Is that the % difference between the new Vtec engagment and stock?? If so, shouldn't be a negative % since you moved the vtec engagement from 5800rpms to 4500 rpms?? That would be a negative change. If I am completely wrong, could you help explain why?
Thanks!!
-Nick
Old Jun 16, 2003 | 10:25 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (Nick248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick248 &raquo;</TD></TR><TR><TD CLASS="quote">I've been somewhat confused regarding the V/T unmt %. I've asked many tuners to elaborate and explain this parameter percentage but no one seems have an answer.
Thanks!!
-Nick</TD></TR></TABLE>
I would like to know this as well. Mine is currently set at 0%.
Old Jun 16, 2003 | 04:17 PM
Black R's Avatar
25 Year Member
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (ActiveAero)
.....basically it helps to think of it as "vtec unmatch" or the amount of fuel you're adding/ subtracting at vtec crossover from lo to hi and vice versa.
That way, you don't have to go into the high throttle maps and change the fuel add each time you are playing around with it on the dyno. You can just add fuel at whatever crossover automatically. If you want to clean it up, then you can go back and add fuel at that particular rpm on the wot maps..... and zero out the unmatch settings. But it's just a quick way to program the fuel on the fly for the crossover.....
Old Jun 16, 2003 | 05:27 PM
buzzman's Avatar
Not too bad there. Here is my plot when I dyno'ed it last year...
http://www.geocities.com/buzzmorgan/gsr.htm
The mods I had when dyno'ed were Skunk2 stage 1 camshafts (untuned) and AEM CAI.
-Buzz
Old Jun 9, 2004 | 03:52 PM
GSRacer1's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">
why would you even waste your time writing that </TD></TR></TABLE>
why would you waste your time on idots, just ignore and move on
Old Jun 9, 2004 | 03:54 PM
GSRacer1's Avatar
i guess i should go and tune my vafc too
Old Jun 9, 2004 | 04:02 PM
cheezthis's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (GSRacer1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRacer1 &raquo;</TD></TR><TR><TD CLASS="quote">
Why did you bring back up a year old thread for no reason?
Old Jun 9, 2004 | 05:32 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRacer1 &raquo;</TD></TR><TR><TD CLASS="quote">i guess i should go and tune my vafc too
I guess you should check the dates on threads before flaming back at people.
Old Jun 9, 2004 | 05:36 PM
Champ R's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
I guess you should check the dates on threads before flaming back at people.</TD></TR></TABLE>
That and with the name "GSRacer1" and quite the flaming signature.
Old Jun 9, 2004 | 06:14 PM
Comp97GSR's Avatar
I am sure he took your advice ....... a frickin' year ago!!!
Old Jun 9, 2004 | 07:42 PM
Seedc2's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (Comp97GSR)
lol!
Old Jun 10, 2004 | 12:23 PM
buffgsr's Avatar
what car are you running the vafc on art???
Old Jun 11, 2004 | 09:41 AM
swtch7's Avatar
Default Re: My Dyno and VAFC settings from Bay Area Dyno Day (buffgsr)
way to bring back a dead thread. look at the last post... that was a while ago.
solofthesouth
Apr 26, 2006 05:12 AM
fro
Oct 10, 2004 08:18 PM
Willard
Jun 7, 2004 08:13 PM
Behan
Jun 12, 2003 04:54 AM
