How did you remove paint from OEM bumper?
Old Jun 14, 2003 | 08:29 PM
DownBoyDown's Avatar
Default How did you remove paint from OEM bumper?
I recently picked up an used OEM bumper for cheap! It has been repainted over the OEM paint and is chipping off. Ive been trying to remove the paint by chipping it off but its taking forever. Does anyone have experience using paint stripper on an OEM plastic bumper? Anyone with first hand experience?
Old Jun 15, 2003 | 08:31 AM
cccya's Avatar
Default Re: How did you remove paint from OEM bumper? (DownBoyDown)
i use some 180 sand paper, then 220 and an obrital sander. finished it out with 400 wet sanding the heck out of it....
Old Jun 15, 2003 | 12:43 PM
JDMTITR's Avatar
Paint stripper and urethane do not mix, if the paint isnt sticking at all i would get a high power pressure washer and try to flake it off, if that doesnt work i would sand, but be careful because you might put waves in the bumper.
Old Jun 15, 2003 | 07:38 PM
Yeah, I was thinking about sanding it but the paint is caked on super thick. I was just scared of actually sanding through to the bumper.
Old Jun 16, 2003 | 10:26 AM
IntEGNYC's Avatar
Default Re: (jz)
dremel!
j/k
Old Jun 16, 2003 | 11:13 AM
PoonHunter's Avatar
Default Re: (DownBoyDown)
there are places that body shops send bumpers to that will fix cracked bumpers, strip the paint of and basicly they make the bumper as good as new. I heard they usualy charge about $70-$100 to restore the bumper back to new. This way you would have no scuff marks or indents or waves on your bumper. It would be basicaly new. They put it in a chemical bath and some thing with heat that makes sure the bumpers are straight and not warped. Its awesome. Body shops do this to save money over brand new factory bumpers. Good luck if you sand it. Id reccomned sanding but since its chipped its a PITA and not worht the time
Old Oct 12, 2005 | 11:21 PM
SlobberGoat's Avatar
Default Re: (PoonHunter)
I'm in the same predicament. I have a rear bumper for a crx where someone went a bit overboard with the white paint.
I'd also like to know of any tricks to help 'restore' it back to OEM.
cthan3o3
Jun 22, 2006 01:46 PM
syoh
Feb 7, 2005 12:57 PM
AcuraTLinspired
Nov 28, 2003 12:50 PM
Soundwave9900
Jan 13, 2003 05:27 PM
