Lower ball joint question
Old Jun 14, 2003 | 11:39 AM
Hartlage's Avatar
Default Lower ball joint question
When I try to screw the castle nut on, the ball joint spins. I know it is not supposed to, but a tech at Honda told me its not that big of a deal. Anyone know any tricks to tighten the nut? Thanx.
Old Jun 14, 2003 | 11:43 AM
blah13's Avatar
Default Re: Lower ball joint question (Hartlage)
Take some thin wire, run it through the hole in the bottom of the bolt and pull it down and wrap it around itself counterclockwise. Slide the nut on the bolt with the wires running through the nut. Grab some vice grips and clamp on the wires and twist them again counterclockwise(because your going to tighten the nut turning clockwise) While holding the vice grips tighten the nut, you should be able to keep the bolt from spinning and when it gets on tight you untwist the wires and pull it out. Badda bing, and dont forget the cotter pin.
Old Jun 14, 2003 | 12:28 PM
chad174's Avatar
Default Re: Lower ball joint question (blah13)
or, put a jack under your control arm to put pressure on it. This is a little easier than the wire trick.
Old Jun 14, 2003 | 02:19 PM
my_slow_civic's Avatar
Default Re: Lower ball joint question (chad174)
Or, slide the stud out, and wipe all the grease and ol off it, and stick a rag through the hole, and clean the grease out of the hole.
Old Jun 15, 2003 | 11:58 AM
Hartlage's Avatar
I tried supporting the lca w/ a jack, but it didn't work. The castle nut is stuck to where I cannot put a piece of wire through the holes.
I'm not sure what you mean by sticking a rag through the hole.
Is it possible to safely drive the car about 15-20 miles with the bolt not tightened?
Any additional help would be great.
Old Jun 15, 2003 | 12:04 PM
senpai's Avatar
Default Re: (Hartlage)
I wouldn't drive 1 mile without that catle nut tightened.
Old Jun 15, 2003 | 12:10 PM
Hartlage's Avatar
Default Re: (maztur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't drive 1 mile without that catle nut tightened.</TD></TR></TABLE>
Thats what I was thinking, but it never hurts to ask!
I have been working on my suspension for a while now, and this one castle nut is the only thing I need to do before it is complete. Getting pissed...
Old Jun 16, 2003 | 01:09 AM
fourthgenhatchB17's Avatar
I have heard of one technique from a friend...he said to put pressure on it while u are tightening it (so if you are lying on ur back, push upwards) and he said that usually works. He also mentioned that if the ball joint is spinning, its worn out.
Old Jun 16, 2003 | 01:13 AM
bossman032's Avatar
I don't think mine is tight.
but I drove 200+ miles NO PROBLEMS
Old Jun 16, 2003 | 12:19 PM
Hartlage's Avatar
I finally got it on. Crossed six lanes on traffic to go to Pep Boys and bought a C-clamp. C-clamped the radius rod to the axle. It's ghetto but it worked.
Old Jun 16, 2003 | 01:09 PM
88ZCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hartlage &raquo;</TD></TR><TR><TD CLASS="quote">I finally got it on. Crossed six lanes on traffic to go to Pep Boys and bought a C-clamp. C-clamped the radius rod to the axle. It's ghetto but it worked.</TD></TR></TABLE>
You are so ghetto.
Old Jun 16, 2003 | 02:15 PM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">Take some thin wire, run it through the hole in the bottom of the bolt and pull it down and wrap it around itself counterclockwise. Slide the nut on the bolt with the wires running through the nut. Grab some vice grips and clamp on the wires and twist them again counterclockwise(because your going to tighten the nut turning clockwise) While holding the vice grips tighten the nut, you should be able to keep the bolt from spinning and when it gets on tight you untwist the wires and pull it out. Badda bing, and dont forget the cotter pin.</TD></TR></TABLE>
I've been trying to picture this all morning and I still can't
Old Jun 16, 2003 | 02:32 PM
Hartlage's Avatar
Default Re: Lower ball joint question (raene)
I tried this just before I used the C-clamp and I think it would have actually worked if I had a piece of wire that was stronger and could still pass in between the castle nut and the bolt. The wire I was using was very thin and broke shortly after I started screwing the castle nut on.
Old Jun 16, 2003 | 03:22 PM
APEX CRX's Avatar
or next time use an electric or air impact gun
tegn00b
Jan 15, 2013 08:23 PM
EX-T
11
Jul 24, 2010 07:57 AM
integra95gsr
Dec 5, 2005 11:06 PM
speed_racer012
32
Mar 12, 2004 02:58 PM
chirp2hrd
May 29, 2003 09:44 PM
