D16Z6 into 89 hatch?
Old Jun 13, 2003 | 11:13 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Default D16Z6 into 89 hatch?
Willa D16Z6 bolt up to 89 hatch engine bay?
Old Jun 13, 2003 | 11:18 PM
Redline130's Avatar
Default Re: D16Z6 into 89 hatch? (MR.RED'89)
As long as you use a cable type tranny, it will bolt in.
Old Jun 13, 2003 | 11:19 PM
JCracer723's Avatar
yes it will. you will need to use your stock transmission, and change the mount on the block(timing belt side). take the z6 out and bolt on your stock 1.
Old Jun 13, 2003 | 11:21 PM
^Sammy]!.'s Avatar
Default Re: D16Z6 into 89 hatch? (JCracer723)
well i want some moe power and 5 speed not 4
so with the D16 tranny it wont bolt in?
Old Jun 13, 2003 | 11:27 PM
Redline130's Avatar
The Z6 tranny won't work due to the mounts and it being a hydraulic tranny. If you meant a D16A6 tranny, then yes, that is the way to go.
Old Jun 13, 2003 | 11:30 PM
^Sammy]!.'s Avatar
Default Re: D16Z6 into 89 hatch? (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">The Z6 tranny won't work due to the mounts and it being a hydraulic tranny. If you meant a D16A6 tranny, then yes, that is the way to go.</TD></TR></TABLE>
so D16Z6 engine wit D16A6 tranny
Old Jun 13, 2003 | 11:32 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED'89 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, the would be the ideal tranny to get for this particular swap.
Old Jun 13, 2003 | 11:35 PM
^Sammy]!.'s Avatar
Thanx Redline im gonna shop around for this setup
Old Jun 13, 2003 | 11:40 PM
JCracer723's Avatar
if u are going to use the stock z6 clutch... make sure u get a 89-91 tranny. 88 diff number of spindles..
gdub604
Transmission & Drivetrain
Jun 12, 2014 05:07 PM
Raocorp
15
May 20, 2009 09:14 AM
tei344
13
Sep 14, 2008 04:18 PM
sk3ch
Sep 14, 2006 06:25 PM
tyflip2
Sep 28, 2003 06:03 PM
