What caused this????? PICS WITHIN!!!!!
Old Jun 13, 2003 | 10:25 PM
P1mpSlap's Avatar
Default What caused this????? PICS WITHIN!!!!!
What could've caused this to happen to my clutch?
Take a guess and play along. Winner gets cookie.
Well anyone wanna take a guess?
Old Jun 13, 2003 | 10:57 PM
Sukebei Oni's Avatar
Default Re: What caused this????? PICS WITHIN!!!!! (P1mpSlap)
dumping the clutch too hard? miss shift? bad driver? granny shifting not double clutching like you should?
Old Jun 13, 2003 | 11:15 PM
rynolone's Avatar
that is very nasty. Did you make that happen or did you buy the car liek that?
Cause I think that clutch is about blow brah
Old Jun 13, 2003 | 11:20 PM
Joel_MN's Avatar
Default Re: What caused this????? PICS WITHIN!!!!! (Sukebei Oni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sukebei Oni &raquo;</TD></TR><TR><TD CLASS="quote">granny shifting not double clutching like you should? </TD></TR></TABLE>
You keep shifting like that, your gonna blow the welds on your intake manifold...and you steel foot plate might fall out!!
Did you put it in reverse?
Old Jun 13, 2003 | 11:21 PM
P1mpSlap's Avatar
ok
Sukebe Oni get da c00kie
Anyways. It was a miss shift. I was letting my friend drive me back home b/c I was feeling shitty. (Dont ask) and he miss shifted when I wasn't looking. I dont remember what gear he was in, but it went into 2nd.
I looked up, saw the tach go into 10K RPM (/me has ITR cluster), had a **** fit and started screaming. Next thing you know, we were coasting into some neghiborhood b/c he couldn't shift the car and the pedal was stiff.
After quick diagnosis, we had to clutchless shift and revmatch my car all the way home (40 miles). Screw paying a 180 dollar tow fee. Engine seems to run fine, and we even did a quick highway pull. Car pulled very strong. Idles fine. Prolly could use a valve adjustment just to make her happy.
But I have an ACT XTSS going in right now+prolite flywheel. So I'll see how it goes once it's finished.
Old Jun 13, 2003 | 11:37 PM
Default Re: (P1mpSlap)
yeah, i won.
yummy cookie!!!!!
Old Jun 14, 2003 | 12:02 AM
startroops's Avatar
Default Re: (Sukebei Oni)
You are one lucky guy since your motor didn't blow up
Old Jun 14, 2003 | 04:02 AM
Dee's Avatar
Dee
Default Re: (startroops)
Looks like the common failure point on a stock clutch. My old clutch did that 5 years ago when I was waiting for a clutch to arrive from Osaka
Old Jun 14, 2003 | 05:18 AM
IntEGNYC's Avatar
Default Re: (Dee)
im at 90500 and im still on my stock clutch.
I think more on the driver than the oem clutch not holding up, as this thread shows. Moral of the story, dont let others drive your teg :D
Old Jun 14, 2003 | 06:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I bet it was hard to shift after that, right? I found the EXACT same thing on my clutch when I pulled it out. Only thing was I didn't misshift or anything, I just rode out 2nd gear to redline one time, and then after that it got hard to shift. I guess it was just waiting to happen w/ 135K on the original clutch.
Old Jun 14, 2003 | 07:18 AM
95integraLS's Avatar
yeah...your friend totally fucked your clutch up! now you have a good excuse to go ACT!!! im still running strong with the stock clutch at 107,xxx miles!!!!
Old Jun 14, 2003 | 07:34 AM
tilt's Avatar
Default Re: (95integraLS)
My friend grenaded my clutch at an autox. A metal bracket broke and the pieces that hold the springs in like yours were all chipped. He went in wayy too fast into a slalom, did a 180 starting sliding at the 2nd cone, sliding backwards all the way to the last slalom cone, and he didnt put the clutch in. byebye clutch
Old Jun 14, 2003 | 07:37 AM
MugenGTR's Avatar
whoa, that's pretty good, considering what happened, feel lucky!
Old Jun 14, 2003 | 08:57 AM
MartyMarGSR's Avatar
Default Re: What caused this????? PICS WITHIN!!!!! (MugenGTR)
i had that happen, two springs cracked, and the hub cracked right down the center on mine tho also.
Old Jun 14, 2003 | 10:36 AM
superfuji57's Avatar
How did you start moving from a complete stop?
Old Jun 14, 2003 | 10:58 AM
Default Re: (superfuji57)
when it happened to me, i started the car in 2nd gear to get moving from a stop in order to be able to have my car limp home. However for me, i couldnt get the car to disengage gear when in motion so i i had to stay in that gear the whole time.
Old Jun 14, 2003 | 11:15 AM
type r 01-1063's Avatar
Either force it in or a rpm speed and speed of travel.
Old Jun 14, 2003 | 01:03 PM
NuclearB18B's Avatar
Default Re: (type r 01-1063)
didn't realize that people were driving on mars already...
Old Jun 14, 2003 | 01:06 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">ok
ummmm cookie!!!!!
91tegra07
Feb 25, 2008 03:00 PM
STEVE-O7
Oct 10, 2007 05:18 PM
teggy2154
Nov 15, 2005 10:33 PM
AspectIndustries
Jan 5, 2004 07:49 AM
faultofhumanity
30
Sep 13, 2003 10:47 PM
