Can I remove the Fast Idle Valve housing on my B17a?????
Old Jun 13, 2003 | 09:31 PM
importimage's Avatar
Default Can I remove the Fast Idle Valve housing on my B17a?????
On the JG edelbrock intake manifold, there is no where for the Fast Idle Valve to be bolted onto the intake manifold for coolant to flow through. Can I just bypass the FIT Valve housing and just run a line from the thermostat housing area to a hole in the intake manifold so it runs through. JG claims that this intake manifold is definelty for my car and the B16a. I say that they made this thing stupid....probably will work good though!!!
Please help!!!
Old Jun 14, 2003 | 06:47 AM
Xsi's Avatar
Xsi
Yes, you should be able to but obviously your car wont idle fast during cold starts
Old Jun 14, 2003 | 07:46 AM
g2 GS-Argh's Avatar
Default Re: Can I remove the Fast Idle Valve housing on my B17a????? (importimage)
Yes, just bypass that coolant line. And remember to give your car time to warm up in the morning.
Old Jun 14, 2003 | 10:46 AM
Default Re: Can I remove the Fast Idle Valve housing on my B17a????? (g2 GS-Argh)
Thanks for your help guys. I figured I could remove it....just wanted to make sure!!!
eglude
Sep 14, 2012 11:53 AM
illprelude
Jul 11, 2008 05:04 AM
RiversideS13
Jul 18, 2007 11:08 AM
trianglegreg
Jan 10, 2006 04:22 PM
kamciu80@aol.com
Dec 6, 2002 07:24 AM
