tach jumping after 4K RPM
Old Jul 20, 2001 | 04:27 PM
boostn5Ghaba's Avatar
Default tach jumping after 4K RPM
I got a b16 in my 94 hb vx and my tach jumps up and down all crazy after 4K rpm. Does anyone knows why and how can I fixed that. All the plugs are plugged in right and the car drives fine. Thanks for you help
Old Jul 20, 2001 | 04:54 PM
blaze's Avatar
Default Re: tach jumping after 4K RPM (boostn5Ghaba)
check the ground strap near your tranny...
Old Jul 20, 2001 | 05:08 PM
Default Re: tach jumping after 4K RPM (blaze)
I'll go and check on that right now. thanks
Old Jul 20, 2001 | 05:14 PM
the ground is there and in good condition. thanks though
Old Jul 21, 2001 | 01:40 PM
raene's Avatar
I'd check the igniter in the distributor. I believe it is responsible for tachometer functioning, and the signs of a failing igniter include erroneous tachometer output.
Old Jul 21, 2001 | 04:57 PM
Default Re: tach jumping after 4K RPM (raeneshadow)
thanks raeneshadow, I was thinking i had to do something with the distributer too. I though it might be the cap, but I'll check both.
Old Jul 24, 2001 | 06:41 AM
sohc_boy's Avatar
do u have an ignition box??? my friend had this prob when his box went bad it caused his tach to jump. he removed the box and the tach worked.
Old Jul 24, 2001 | 12:55 PM
Default Re: tach jumping after 4K RPM (sohc_boy)
No I don't have an ignition box. I was going to install one when I get my turbo but right now it's stock. I think it's the ignition coil in the distributor. thanks for you help though
Old Jul 25, 2001 | 04:18 PM
fixhondas's Avatar
usually this is caused by loose connections on your igniter- pull off each wire and tighten the ends with pliers.
Old Jul 27, 2001 | 09:30 PM
H22CIVIC's Avatar
New User
Have you solved it yet? I just had this happen to me last night. I to thought it was the connections on the igniter. Everything was tight though. I replaced it and now my car is back to normal! I hope this helps!
Old Jul 29, 2001 | 03:51 PM
Default Re: tach jumping after 4K RPM (H22CIVIC)
I'm going to check on the connections tonight, but I'm in the process of looking for a new distributor just in case. Can I just replace the ignitor?
Old Jul 30, 2001 | 07:18 PM
fixhondas's Avatar
yes- you can replace the igniter itself
crxb16ftw
Jun 20, 2007 12:02 PM
Turbo_TONY
Mar 21, 2007 08:46 PM
wizzards581
Oct 25, 2003 11:02 PM
accordfan
Oct 30, 2002 11:44 AM
Ya@inlinePRO
Jul 16, 2002 03:17 PM
