Need help on a HID diagnosis
Old Jun 13, 2003 | 06:38 PM
Tweakmeister's Avatar
Default Need help on a HID diagnosis
We're having a *hid install party* over here, and we can't figure out why the system isn't working.
Ballasts are wired up and are working (they provided quite a jolt to fellow member "misfit" )
I think the bulbs are busted.
Old Jun 13, 2003 | 06:39 PM
JDM CTR EK's Avatar
Default Re: Need help on a HID diagnosis (Tweakmeister)
are those H4 bulbs? Post a pic of them workin' once you get done and the GRADE of the HID's. I wanna see. Sorry I can't help.
Old Jun 13, 2003 | 06:47 PM
Default Re: Need help on a HID diagnosis (JDM CTR EK)
haha will do man
I think they're "blown" I know HID have a gas arc so I can't just test them on the multimeter.
Like what is that milky looking stuff in the bulb?
edit\\\ Milky looking stuff is fine according to the other pics I've seen.
This leaves...connectivity issue?
Old Jun 13, 2003 | 07:10 PM
skafia's Avatar
25 Year Member
If it gave you a shock then the connection is good.
Did you replace your fuses to 20A?
Old Jun 13, 2003 | 07:17 PM
Default Re: Need help on a HID diagnosis (skafia)
would they not still work (and maybe blow the current fuse)?
Old Jun 13, 2003 | 07:20 PM
skafia's Avatar
25 Year Member
If you didn't replace with 20A fuses and turned the system on, they would blow the stock fuses and not work. Replace them and your headlights would work, I promise.
Old Jun 13, 2003 | 07:22 PM
this is how they're wired up now (and not working).
Old Jun 13, 2003 | 07:23 PM
alrighty >> I'll test the factory headlight bulbs again to see if the fuse is blown.
thanks man...I'll keep you posted
Old Jun 13, 2003 | 07:49 PM
ebelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR EK &raquo;</TD></TR><TR><TD CLASS="quote">are those H4 bulbs? Post a pic of them workin' once you get done and the GRADE of the HID's. I wanna see. Sorry I can't help.</TD></TR></TABLE>
They look like 9006 bulbs to me. Did you put that ring adapter on yourself? The bulbs look good to me...can't really tell anything by the pics.
Old Jun 13, 2003 | 08:22 PM
Denny's Avatar
Default Re: Need help on a HID diagnosis (ebelp)
i think that white milky substance is silicon
Old Jun 13, 2003 | 08:24 PM
TnEG2
Guest
Posts: n/a
h.i.d... wetbacks call it HID.. like G.S.R. they say GGGSSSRRR!
Old Jun 13, 2003 | 08:35 PM
Default Re: Need help on a HID diagnosis (161822-tuan)
yes, we did the 9006 retrofit.
no fuses are blown and we still can't get it to work.
Josh is going to drive home for now...I still can't figure it out
Old Jun 13, 2003 | 09:23 PM
Understeer's Avatar
Hmm, is this normal? (I circled it)
Old Jun 13, 2003 | 09:48 PM
Misfit's Avatar
Default Re: Need help on a HID diagnosis (Understeer)
I think that is just a shield... meaning its just to protect that wire going across. so long as the wire isn't broke it should be ok. I could be wrong though
Old Jun 13, 2003 | 09:57 PM
yeah the crack is fine, but thank you
we will go ahead and replace those 10 amp fuses with some 20's (even if they aren't blown). We're thinking the system just needs the 20 amp capacity to perform.
Old Jun 14, 2003 | 12:32 AM
skafia's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">yeah the crack is fine, but thank you
we will go ahead and replace those 10 amp fuses with some 20's (even if they aren't blown). We're thinking the system just needs the 20 amp capacity to perform. </TD></TR></TABLE>
THAT'S WHAT I WAS TELLING YOU ALL AFTERNOON
Sorry for the caps + bold
Old Jun 14, 2003 | 12:53 AM
COMplex.'s Avatar
hmm.. maybe you can help me with my problem.
when i turn on the HIDs:
driver side turns on
passenger side flickers for half a second then goes right off.
i have 20 or 25A fuses, can't remember fully, but do you think it could be a ground of the passenger side?? i thought i made it good enough.
hopefully its not a sign of a blown ballast or bulb.
i mean, it comes on for less than an instant and just turns off, so i'm guessing its not the bulb. most likely not the ballast. er.. i dunno. HELP please.
Old Jun 14, 2003 | 01:32 AM
NUTWEAVE's Avatar
Default Re: Need help on a HID diagnosis (j.fuggi)
i just got my HIDs put in a couple days ago.
i think i know what your problem is...
you have "reverse polarity"...that's what my problem was. i hooked everything up correct and they didn't work.
there is a plug coming from your stock halogen bulbs...it's white. it has 2 prongs inside of it and a clip on top.
now you normally plug that into the plug on the wiring harness that connects it to the ballast. the correct way to plug it in will make them "clip" together, making you THINK you plugged it in right.
well, if you have "reverse polarity" you are not doing it right. flip the connector upside down and push it in ALL THE WAY, until you feel a click. then try it, it should work. make sure you plug it in all the way though. reverse polarity happens to random cars. both of my lights needed to be plugged in oppositely while some will work with the setup they give you.
Old Jun 14, 2003 | 02:17 AM
Mario's Avatar
Default Re: Need help on a HID diagnosis (TypeR882)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR882 &raquo;</TD></TR><TR><TD CLASS="quote">i think that white milky substance is silicon </TD></TR></TABLE>
Nah, it's normal. The residue is the salt halide particles, an essential part of any hid xenon bulb.
Old Jun 14, 2003 | 07:35 AM
ek9vboi
Guest
Posts: n/a
i had a problem just like you guys, but it was the fuse after all. with the 10 amp fuse, you need to turn on the motor so that it doesn't blow the fuse. withg the 20 amp you can turn it on without the motor on without a problem. right now i have 25 amp fuses in place of the 10 amp fuses. rarely does the bulb burn out, but it does. i highly doubt that this is the case and the ballast blown...highly doubted, unless you bought this kit used. if i were you check the fuses!!!
Old Jun 14, 2003 | 05:55 PM
magnetic1's Avatar
Default Re: (ek9vboi)
The fuse thing is NOT the issue. If they aren't blown, you don't need a higher amperage fuse. The whole point of a fuse is to protect the system in case of high current. If a 10Amp fuse is not blown, then running a 20A fuse does nothing.
The crack, while not normal, will not be the casue of the system not working. Even if the wire was indeed cut somehow, ONE side would still work.
The milky substance is normal. It is just the gas/salts inside the HID capsule.
I would check on the reverse polarity as mentioned a couple posts above. That is most likely the issue.
Also... glued bases =
Old Jun 14, 2003 | 06:41 PM
Default Re: (magnetic1)
the glued bases we did ourselves. honestly I think they're fine (with the high-grade 30year silicone I used...stuff is bombproof ).
You can see I cut the bases to make it snap over like it looks like it should go. if you guys are saying the factory halogen clip should be on the opposite side of what should work then I will certainly try that.
I will post up tomorrow hopefully with what happens.
Old Jun 14, 2003 | 07:51 PM
airon's Avatar
Default Re: Need help on a HID diagnosis (NUTWEAVE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NUTWEAVE &raquo;</TD></TR><TR><TD CLASS="quote">i just got my HIDs put in a couple days ago.
well, if you have "reverse polarity" you are not doing it right. flip the connector upside down and push it in ALL THE WAY, until you feel a click. then try it, it should work. make sure you plug it in all the way though. reverse polarity happens to random cars. both of my lights needed to be plugged in oppositely while some will work with the setup they give you.</TD></TR></TABLE>
werd same thing happened to me on my integra 9006 install
unlike halogens, the hids and ballasts need the polarity's to be correct
you can check them by using a multi meter or juts by flipping the the connection
Old Jun 15, 2003 | 02:18 AM
B20C5 Turbo's Avatar
New User
Just make sure that your battery voltage is above 11.0V. The balast will 'drop out' @10.5V.
Old Jun 15, 2003 | 03:45 AM
magnetic1's Avatar
Default Re: Need help on a HID diagnosis (B20C5 Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20C5 Turbo &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure that your battery voltage is above 11.0V. The balast will 'drop out' @10.5V.</TD></TR></TABLE>
That is not true. The ballast's circuitry should allow for operating voltages to drop as low as 7.2V I believe on the LV-212
