rear disc brakes question....... need to know ASAP
Old Jun 13, 2003 | 03:26 PM
hulkhb's Avatar
Default rear disc brakes question....... need to know ASAP
Do 92-95 civic SI/EX rear disc brake swap fit on the CRX ??? 88 HF model.
TIA
Old Jun 13, 2003 | 04:04 PM
eraser's Avatar
Default Re: rear disc brakes question....... need to know ASAP (hulkhb)
all rear disc setups are interchangable from 88-2000
you just have to use the proper mix and match of hardware from your car and the donor setup
Old Jun 13, 2003 | 04:14 PM
USDM 4G VTEC's Avatar
i am not 100% sure but i something tells me that it doesnt!
Old Jun 13, 2003 | 04:27 PM
andrew dc's Avatar
Default Re: rear disc brakes question....... need to know ASAP (eraser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eraser &raquo;</TD></TR><TR><TD CLASS="quote">all rear disc setups are interchangable from 88-2000
you just have to use the proper mix and match of hardware from your car and the donor setup</TD></TR></TABLE>
true!!! that is why I am selling my disc brakes as 88-00
Old Jun 13, 2003 | 04:39 PM
zCivic's Avatar
they will work. You will need 90-91 crx SI e-brake cables though
Old Jun 13, 2003 | 05:54 PM
hulkhb's Avatar
Default Re: rear disc brakes question....... need to know ASAP (zCivic)
so its a straight over swap or maybe i'll have to use the CRX lca's ?
just want to make sure before my boss buys them to install on his 88HF.
more info or details would be great, thanks.
Old Jun 13, 2003 | 06:01 PM
JCracer723's Avatar
yes they do fit.. yes its a good idea to use ur stock lcas
Old Jun 13, 2003 | 07:58 PM
fourthgenhatchB17's Avatar
The rear discs will fit but like someone else said u r gonna need the '91 CRX SI ( the CRX model that came with the disc brakes already)E brake cables. I have a pair of those cables cuz i did a conversion on my hatch and used the CRX rear setup. But i couldnt use the CRX cables on my hatch so i have them for sale. E-mail me at ejk1976@email.msn.com if interested.
Old Jun 14, 2003 | 12:49 PM
chad174's Avatar
you can also use 90-93 integra cables.
Old Jun 14, 2003 | 01:23 PM
zCivic's Avatar
Default Re: (chad174)
you can use either the 90-93 tegs or any civics but there gonna be too long and xtra work involved in re-routing them. E-brake cables are enough of a bitch just same yourself some time and cussing and get the SI's IMO
SPL KID
Apr 26, 2005 03:55 PM
superbeastcrx
Jan 18, 2005 08:39 AM
boost'dsiR
Jan 2, 2005 07:51 PM
BOSS-REX
15
Oct 2, 2004 03:56 PM
CRX SiR T
Jul 1, 2003 12:19 PM
