Lower idle....
I have a 91 crx si wit a 95 gsr, i just bought a lightened flywheel and got it put in now my idle is a steady 1200 i took the peice off the back of the intake manifold and clean that i put carb cleaner in the TB so the idle isn't up and down... the scew on the TB doesn't help to change the idle...wat else should i do to lower my idle to around like 750 to 800....no ecu codes either are being thrown... i took my JG intake manifold off i am using the stock IM
bmanuhutu
Apr 26, 2010 07:41 AM
