Problems after replacing the engine in a 91 CRX 1.5l
Old Jun 13, 2003 | 06:13 AM
Todd K's Avatar
Default Problems after replacing the engine in a 91 CRX 1.5l
Had an Engine replaced at 101,500. When I got the car back from the shop the check engine light was on. So I looked up the codes 10 (Ta Sensor) 14 (Eacv). Car would idle hunt so I replaced the EACV. Still did it and the check light was still on. So I replaced the TA sensor still no change. Spoke to a honda guy and he told me to disconnect the Map sensor to see if that fixed the idle problem. When I disconnected the map sesor the car idles fine. So I replaced it too. But still idle hunts. So I checked for vacuum leaks by spraying ether on the manifold and around all vacuum lines. No change in idle. So I was hoping you guys could point me in the direction to look next.
Thank you
Old Jun 13, 2003 | 08:37 AM
one slow d16's Avatar
Default Re: Problems after replacing the engine in a 91 CRX 1.5l (Todd K)
iacv?
Old Jun 13, 2003 | 08:50 AM
tpr's Avatar
tpr
Reset your warm idle. Get the car to operating temperature. Unplug the EACV using the idle speed screw top rear of the Throttle body set the idle to ~750 RPM. Plug the ECAV back in and it should help. If this is not sucessful then chech the TPS voltage it should be ~0.5 volts +/- 0.05. at idel with the car off. The voltage is measured at the center wire and the Green/white wire not sure about the Green/white.
Good Luck!
Old Jun 13, 2003 | 09:06 AM
Todd K's Avatar
Default Re: Problems after replacing the engine in a 91 CRX 1.5l (tpr)
Thanks for the tip. You helped me fix it by mentioning the color of the wires. I went and looked and the guy who installed my engine had the connectors reversed on the TA and the EACV. Got rid of the idle hunt but I'm still showing a code 10. But at least it idles better now. Thanks alot.
greenzchatch
Jul 29, 2010 02:14 PM
bads2k
Feb 2, 2010 10:07 AM
CHK4TIX
Jan 27, 2007 05:24 PM
wkdalpha
Feb 15, 2006 08:55 PM
firefly
Oct 12, 2001 08:39 PM
