cel question...may do better in the integra forum tho??
Hey guys,
ahhhhhh lol....can someone explain how I get a code 43 on my obd0 LS crx??? I checked and my friend double and triple checked for me and sure enough its code 43 - unless we are both idiots.......... im a little frusterated with this one....any help would be great
ecu says:
long long long long short short short
no pauses
also...we swapped ecu's so I know I am running the proper ecu...threw code in both (pr4)
ecu says:
no pauses
ok...if I had an obd1 vehicle it would be fuel supply...but I have always been under the impression that obd0 goes 1-20
Is the CRX a HF by chance? If so, you may need to cut wires B9 and B11 at the ECU plug. This is HF only stuff and will freek out any other ECU. I had to do mine to make the check engine light go off.
HTH
chris
HTH
chris
