wat r causes of squeeks off the alternator?
Old Jun 12, 2003 | 08:40 PM
wizzards581's Avatar
Default wat r causes of squeeks off the alternator?
wen i start my car it squeeks for couple secs... wat can be cause?
Old Jun 12, 2003 | 08:47 PM
neilff's Avatar
Default Re: wat r causes of squeeks off the alternator? (wizzards581)
new altenator belt
maybe the pulley is warped
Old Jun 12, 2003 | 08:52 PM
Default Re: wat r causes of squeeks off the alternator? (neilff)
it is a new alternator belt and new alternator ... also new battery too... now my battery is leaking acid like the one before. defects off the alternator?
Old Jun 12, 2003 | 08:56 PM
93eg-EKhybrid's Avatar
It could be that your belt needs to be tightened more. Alternators do not usually negatively affect batteries unless the voltage regulator goes bad and overcharges the battery. That is also a rarity though since most of the time when a voltage regulator goes bad it will either undercharge or not charge at all.
Old Jun 12, 2003 | 09:37 PM
ViZiONiZM's Avatar
Default Re: wat r causes of squeeks off the alternator? (93eg-EKhybrid)
i had the exact same problem when i just had the LS swap, this can be solved by loosening the alternator kindabit and move it the opposite force of the belt, therefore making it tighter... after that is all done, retighten the bolt(s) that hold the alternator in place.
Old Jun 12, 2003 | 09:50 PM
eg_nezay's Avatar
Yup, sounds like you just need to tighten your belt.
Old Jun 12, 2003 | 10:12 PM
gary201147's Avatar
Default Re: wat r causes of squeeks off the alternator? (eg_nezay)
I dont quite understand this, tell me if my logic is wrong... If it is loose, that means that the alternator is not doing its job to the greatest potential, which means it would not be able to overcharge a battery which causes the overflow of water from the batery. So since his battery is still over flowing, couldnt you rule out the possiblity of a loose belt?
Old Jun 14, 2003 | 11:55 AM
Default Re: wat r causes of squeeks off the alternator? (gary201147)
well actualy my belt isnt too tight or loose... but wen i start my car i pulled my (+) bat off and the car died... false alternator. it was a new one too but aftermarket. i was thinking of dealership but now ill have to go there. should i jux change the brushes inside?
Old Jun 14, 2003 | 01:32 PM
bump! anyone help?
Old Jun 14, 2003 | 01:41 PM
Sephiroth's Avatar
Well i was gonna suggest new alternator but cross that idea out. Why dont you just replace the belts?? i dont think its a loose belt.
chief smackahoe
Sep 30, 2013 09:54 PM
92eg_b16
Jan 31, 2008 08:15 PM
dohc_profile
May 31, 2006 06:45 PM
mjrage
Jul 4, 2004 01:06 AM
