Sohc vtec cams
Can I replace my cam on my d16y8 to a better performance cam. I wasnt sure because it is SOHC, if there is an aftmrkt one are there any other mods I have to make to the car, and how how hard would it be to install. Would the timing belt have to be replaced and re adjusted?? Thanks for any help!
Crane Cams have a d16y8 cams
http://www.cranecams.com/import/hsvteccams.htm
and so does Crower cams
http://www.crower.com/cat/impo...shtml
Zex also makes a couple nice ones. You can use the 59300 for the d16z6, just use a z6 cam gear or an adjustable cam gear and retard the timing 5 degrees.
MrTodd
Aug 23, 2003 10:14 AM
lonefuzzy79
23
Apr 25, 2002 02:26 AM
