bogging problem on b16
Old Jun 12, 2003 | 05:57 PM
Rob!'s Avatar
Default bogging problem on b16
everyonce in awhile my car will bog...i just got it on the road and sometimes ill be driving fine and everything then the tach will jump all over the place crazy fast then the car will bog and when i hit the gas it dies down more...anyone ever experience this problem? it only does it sometimes but when its not doing it...the car runs very strong. help me out
Rob
Old Jun 12, 2003 | 06:06 PM
bossman032's Avatar
Default Re: bogging problem on b16 (b16hf)
maybe fuel PUMP Problem?
Old Jun 12, 2003 | 08:02 PM
Rob!'s Avatar
Default Re: bogging problem on b16 (bossman032)
someone had to have this same problem..!!!
Old Jun 12, 2003 | 08:32 PM
elmalouno's Avatar
i'd bog too if i had to tote your fat *** around!
someone help the man
Old Jun 12, 2003 | 10:00 PM
incubus's Avatar
Default Re: bogging problem on b16 (elmalouno)
your ECU throwing any codes? mabey a 7?
Old Jun 12, 2003 | 10:36 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: bogging problem on b16 (incubus)
Could be grounding as well. Had this same problem on my ZC (not the same motor but you got nothing to loose) and i noticed that 2 grounds werent right and i tightened them and it worked for me.
The ecu might be throwing a code as well. I have seen O2 sensor codes make this happen.
Old Jun 12, 2003 | 10:41 PM
pokemon's Avatar
BAd alternator sometimes will cuse that, sorry I am drunk.
Old Jun 13, 2003 | 05:13 AM
Rob!'s Avatar
Default Re: (pokemon)
it throws a code when the check engine light comes up but then goes off very fast....anyone know???
Old Jun 13, 2003 | 07:06 AM
REDBARON's Avatar
Default Re: (b16hf)
Did you check the ecu? Just because the CEL turns off, doesn't mean that the ecu is not still throwing the code. Check the ecu, and let us know.
Old Jun 13, 2003 | 07:36 AM
UK CIVIC B16A2's Avatar
sounds like it could be a wireing fault like the earths. the only way i know that the engine warning light would go off is if the ignition was turned off, which suggests to me that theres a fault somewhere in the ignition barrel or there-abouts. this probably could cause the rev counter to spike/drop. also if it had a bad connection and a reduced voltage/current this would affect performance(spark voltage or fuel pump speed). this would also explain the intermitent nature of it.
Old Jun 13, 2003 | 07:44 AM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hf &raquo;</TD></TR><TR><TD CLASS="quote">everyonce in awhile my car will bog...i just got it on the road and sometimes ill be driving fine and everything then the tach will jump all over the place crazy fast then the car will bog and when i hit the gas it dies down more...anyone ever experience this problem? it only does it sometimes but when its not doing it...the car runs very strong. help me out
Rob</TD></TR></TABLE>
Tach jumping makes me think the igniter is going bad. If the igniter poops out then your tach will fly all over the place (it sends the signal to the tach). Mine is going out too
I'd start by replacing your igniter - a piece from a CRX Si will work fine. If the car still bogs after that (sounds to me like the fuel pump is dying) then we'll diagnose that - but let's fix the tach first mmmkay?
Old Jun 13, 2003 | 07:50 AM
Rob!'s Avatar
Default Re: bogging problem on b16 (raene)
well heres whathappened....before i got my b16 to run i bought a new ignitor because thats why i thought i was getting no spark....but i checked them both with an ohmeter when i took the old one out and they were the same....but i put the new one in anyway....so today i went back and put the old ignitor in and i still have the same exact problem...any other suggestions?
Old Jun 13, 2003 | 07:55 AM
raene's Avatar
So you had the new igniter in for a day? And it still had the same problem with the new piece? Why did you put the old one back in?
Old Jun 13, 2003 | 07:57 AM
Rob!'s Avatar
i had the new one in for like a month....i never really drove the car because of other problems like insurance so i didnt notice the bog problem cuz it only happens after i drive for a bit....but....today i put the one i use to have in before i got the new one and i have the same problem basically with 2 different ignitors i have the same exact problem
Old Jun 13, 2003 | 08:07 AM
raene's Avatar
Dang, it isn't igniter then
I hate intermittent problems
Have you ever noticed the bogging problem separate from when the tach jumps, or are they simultaneous always?
Old Jun 13, 2003 | 08:15 AM
Rob!'s Avatar
they always go hand and hand....sometimes the tach will jump without bogging but almost everytime the bog goes along with it....woohooo 1000 posts dang b16 rex
Old Jun 13, 2003 | 09:23 AM
raene's Avatar
Well... what I would try doing is hooking up a voltmeter and driving it to see if the volts drop/cut out when the bogging happens... without more info it's hard to say, but it really does sound like the car is cutting off, not just the pump...
Old Jun 13, 2003 | 09:53 AM
white99gsr's Avatar
do a continuity test on the TPS Sensor, make sure there aren't any flat spots when your opening the butterfly. i dont know if that will cause the needle to jump around but it will make it bog real bad at a certain throttle position.
gook
30
Sep 29, 2005 10:14 AM
zccrx
Jun 27, 2003 07:45 PM
juicy.koreans.suck
Mar 21, 2002 04:36 PM
