helpppp....... my trunk leaking
Old Jun 12, 2003 | 03:40 PM
paeaknoy's Avatar
Default helpppp....... my trunk leaking
heres the story....... when it rains or when i wash my car. My rear trunk tends to leak its coming from the right side by the tail lights. its not the tail light seal cause i replaced them already btw i got a 98 integra 4 door. all i know is that its coming from the right side of the trunk. anyone got the same problem let me know how u fixed it thanks
Old Jun 12, 2003 | 04:09 PM
boosted_dc2's Avatar
Default Re: helpppp....... my trunk leaking (paeaknoy)
do you have altezza's??? if so thats your problem there the biggest pieces of **** made...
Old Jun 12, 2003 | 05:53 PM
J337_UNIT's Avatar
Default Re: helpppp....... my trunk leaking (hooked_up_gsr)
i have the same problem (stock tailights), i believe its my gaskets
Old Jun 12, 2003 | 05:55 PM
Grandprix's Avatar
Default Re: helpppp....... my trunk leaking (J337_UNIT)
i took a drill and drilled two holes in the floor under the spare tire.
Old Jun 12, 2003 | 05:57 PM
jdmotorsports's Avatar
Default Re: helpppp....... my trunk leaking (Grandprix)
check the trunk seal for tears. also make sure all the gaskets are ok and that the nuts are tightened down to the right torque.
Old Jun 12, 2003 | 06:44 PM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hooked_up_gsr &raquo;</TD></TR><TR><TD CLASS="quote">do you have altezza's??? if so thats your problem there the biggest pieces of **** made...</TD></TR></TABLE>
probaly do
Old Jun 12, 2003 | 06:48 PM
JDubya's Avatar
It's prolly the tail light gasket. Or it could be the sunroof drain tube (if u have a sunroof) but even then the drain tube is more to the side of the car, so i dunno...
Old Jun 12, 2003 | 07:28 PM
theman-dlh's Avatar
Default Re: helpppp....... my trunk leaking (ALL MOTOR LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS &raquo;</TD></TR><TR><TD CLASS="quote"> Or it could be the sunroof drain tube (if u have a sunroof) but even then the drain tube is more to the side of the car, so i dunno...</TD></TR></TABLE>
I'd check that If I were you Ive had it pop out before.
Old Jun 12, 2003 | 08:12 PM
SMZ GSR's Avatar
Default Re: helpppp....... my trunk leaking (theman-dlh)
if it's the taillight gaskets contact user ragejed...he sells some for cheap and they're really good. I use them myself
Old Jun 25, 2003 | 05:15 PM
paeaknoy's Avatar
its none of the tail light gaskets cause i replaced them already. i still have the stock tail lights on cause i think all red tail lights look way better than altezzas. it isnt the sunroof drain tube cause i plugged it back in when i came loose, but still got leakes anyone can help me out here
Old Jun 25, 2003 | 07:55 PM
rapid_roy's Avatar
If you have a sunroof, check the draintubes in the back. The rubber tubes connect to a plastic elbow connector behind the tail lights. Sometimes that becomes disconnected.
Old Jun 25, 2003 | 10:42 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paeaknoy &raquo;</TD></TR><TR><TD CLASS="quote">its none of the tail light gaskets cause i replaced them already. i still have the stock tail lights on cause i think all red tail lights look way better than altezzas. it isnt the sunroof drain tube cause i plugged it back in when i came loose, but still got leakes anyone can help me out here </TD></TR></TABLE>
Everyone says it's not the taillight gaskets.....but it is. Trust me. Just replacing them won't do. Make sure you install them correctly. Put on some silicone sealant if necessary. Make sure it is held on tight. Push on the taillight and screw in those nuts by hand little by little as you put hard pressure on the taillight toward the front of the car.
It is your taillight gasket.
Old Jun 26, 2003 | 03:40 AM
ebelp's Avatar
Default Re: helpppp....... my trunk leaking (IntegRaVeR615)
It's funny how he's said that it's not his taillight gaskets like 5 times, but everyone still keeps saying, "maybe it's your taillight gaskets".
I actually also drilled a small hole in my spare tire well. I have new taillight gaskets from ragejed too ( ), but my trunk still leaks a bit. Drilling a hole is just a good temporary fix until you find out where the leak is coming from.
Old Jun 26, 2003 | 04:27 AM
Duckz's Avatar
Default Re: helpppp....... my trunk leaking (ebelp)
well take you back seats out, get in the back of the car and stick you head in the trunk with a flash light, and have a friend soak the car with a hose for a few minutes while you are inside looking for leaks
i have also heard about the atenna causing leakage problems.
Mr JDM South
16
Apr 4, 2017 07:08 PM
90AccordTx
Jun 23, 2005 06:43 PM
Kryptonite
Aug 26, 2003 09:57 PM
JDubya
Jun 3, 2003 09:42 AM
TeamTooQuick
Apr 9, 2002 10:36 PM
