Rear Disc Brake Conversion Question Not Asked Before!
From: With my POS D15B2, Whereever whenever, United States
Yeah my question is
I got the complete set of rear disc brake conversion off a 90-93 teg.
The thing is, my passenger side trailing arm is bent.
Can I use my old Civic trailing arm?
Thanks
Thanks
you positive, because I look at it this way.
If I do it, I want it all to be the same, so I will just convert and add out both the integra disc on the civic trailing arms.
The civic is also shorter so do i put back the civic e brake cables or the integra ones
Modified by MugenHonda at 4:43 PM 6/12/2003
what do i do with the ebrake cables though?
Any thoughts
thanks
because if I use the civic trailing arms, i don't need the cable to be as long right or do I still need the integra e brake cables because of the disc swap?
Any more help
thanks
Any thoughts
thanks
Any more help
thanks
I got a hatch, but it still comes down, can i still use my trailing arm and swap the disc set up over there?
Move the hubs/cables over to the civic trailing arms. I've heard of people who suggest this as the easiest way to swap the brakes. I've never done it, but I do remember 3-4 posts where people suggested this as the easiest method.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">I got a hatch, but it still comes down, can i still use my trailing arm and swap the disc set up over there?</TD></TR></TABLE>
yes you can, you will need the integra ebrake cable.
mynameizstitch
10
Dec 13, 2009 03:06 PM
vtec-adykt
Jan 27, 2005 07:13 PM
