Kill switch question
Old Jun 12, 2003 | 01:10 PM
smokinvtecCRX18's Avatar
From: yea thats right i got a flowmaster and it owns you, Oklahoma, usa
Default Kill switch question
theres four wires going to the fuel pump, I was told to splice into the wire yellow with the green stripe in order to do a fuel pump power wire kill, but i only have a yellow with white stripe, yellow with a black stripe, and two black wires. Which one do i use?
thanks
Old Jun 12, 2003 | 01:18 PM
Default Re: Kill switch question (smokinvtecCRX18)
anybody?
Old Jun 12, 2003 | 02:17 PM
Outsane's Avatar
I have made kill switches by cutting the yellow wire and putting an on/off switch on it make sure you get one that can handle some good joice, or it could melt..
Some peole are touhy about posting anti-theft info on the web that may be why your not gettin a response...
just hide the switch, or think of something clever..
Old Jun 12, 2003 | 04:02 PM
raene's Avatar
Default Re: Kill switch question (Outsane)
Use a pin to unclip each wire from the harness and try to start the car, one at a time. One of the wires is for your pump power. One is for pump ground. One is for fuel level sender power, and one is for fuel level sender ground. Either pump power or pump ground can be used to wire in a kill switch - the ground will be black.
HTH
i tried the yellow wire with the white stripe and it is my fuel guage which should i try next, the yellow with black stripe or the black with white stripe or the other black one, by the way i dont have the yellow wire with green stripe so i dunno any help would be great im ing my self right now
Old Jun 15, 2003 | 11:48 AM
travis's Avatar
Are you trying to wire a true kill switch, or just a starter disable switch. They're different.
Old Jun 15, 2003 | 01:31 PM
Hcivic88's Avatar
Default Re: Kill switch question (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">One of the wires is for your pump power. One is for pump ground. One is for fuel level sender power, and one is for fuel level sender ground. Either pump power or pump ground can be used to wire in a kill switch - the ground will be black.
HTH </TD></TR></TABLE>
I thought that the pump was grounded right to the tank from the pump housing? and that there wasnt a ground wire??
did i hear wrong?
all_motor
Feb 3, 2013 11:30 AM
B16CRXT
18
Dec 12, 2004 07:45 PM
B16CRXT
Dec 10, 2004 03:40 PM
StreetRacnGsR
23
Jun 18, 2003 05:05 AM
VTECAcuraGSR
Apr 10, 2002 12:04 PM
