H23 ECU on H22 engine?
Old Jun 12, 2003 | 11:41 AM
willhoman's Avatar
Default H23 ECU on H22 engine?
Anyone done this....When i had my h22 put in, I did not get the p13 ecu, instead I kept the h23 ecu an my mechanic wired up VTEC to a switch, so i can activate it anytime i want, the only problem is......I have fuel cut off at like 7200 which kind of sucks, but i have not ran it in the 1/4 mile or done a dyno test so i really cant tell you how it is? uhhh is this stupid? any comments at all is all good...
Old Jun 12, 2003 | 11:46 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: H23 ECU on H22 engine? (willhoman)
the only real downside to that is the rev limiter being so low, i was gonna just use my LS ECU when i built my LS/VTEC and use an RPM switch, but managed to get my own ECU, but yeah, that's not a bad idea, just suck that you are hitting rev limit when you should be making the most power
Old Jun 12, 2003 | 11:48 AM
willhoman's Avatar
Default Re: H23 ECU on H22 engine? (Boosted97Lude)
yeah, but like is my low end power suffering with this ecu?
Old Jun 12, 2003 | 11:50 AM
Boostless97Lude
Guest
Posts: n/a
low end prbably isn't, you high end will suffer more, b/c it's not adding more fuel after VTEC engagment like it should
Old Jun 12, 2003 | 11:51 AM
willhoman's Avatar
o well he (the mechanic) said that the switch controls VTEC, more fuel, and something in the intake manifold to allow more air...
Old Jun 12, 2003 | 11:59 AM
Boostless97Lude
Guest
Posts: n/a
the "something" on the intake manifold was also on you H23, so it should engage as well, that shouldn't be affected
Old Jun 12, 2003 | 12:03 PM
willhoman's Avatar
hmmm alright thats cool, do you understand the "fuel" thing though, an would it be a good invertment for say a chipped p28 ecu?
Old Jun 12, 2003 | 12:06 PM
tha Big EZ's Avatar
Default Re: (willhoman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willhoman &raquo;</TD></TR><TR><TD CLASS="quote">hmmm alright thats cool, do you understand the "fuel" thing though, an would it be a good invertment for say a chipped p28 ecu?</TD></TR></TABLE>
of course. it would be Honda reliable ( to an extent). , insted of an rpm activation switch. that is whatcha got isnt it?
Old Jun 12, 2003 | 12:09 PM
willhoman's Avatar
Default Re: (Tomithicus)
ummm i guess if thats what you want to call it, it just a switch that i hit to change over to vtec, hit it again an im out of vtec, lol, i dont know what you call it
Old Jun 12, 2003 | 12:49 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willhoman &raquo;</TD></TR><TR><TD CLASS="quote">ummm i guess if thats what you want to call it, it just a switch that i hit to change over to vtec, hit it again an im out of vtec, lol, i dont know what you call it</TD></TR></TABLE>
that sounds prety dangerous to me. if i was you i would DEFINETLY invest in a new ecu. so you have to push a button when you want to engage vtec?
Old Jun 12, 2003 | 12:53 PM
willhoman's Avatar
yup, its a switch......hmmm i dont know what to think? what about a p28 chipped spoon ecu off of ebay? is it just a plug an play thing when you install it or what
Old Jun 12, 2003 | 01:00 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willhoman &raquo;</TD></TR><TR><TD CLASS="quote">yup, its a switch......hmmm i dont know what to think? what about a p28 chipped spoon ecu off of ebay? is it just a plug an play thing when you install it or what</TD></TR></TABLE>
i wouldn't trust anything off of ebay (as far as ecus are concerned). if i was you i would try to find a company that sells ecus. which one to get is a matter of opinion, p28, p72 have their plus and minuses (do a search on this) but you must have both of these setup to run on an h22. if money is a concern or just want the correct ecu, buy a p13. there are a number of different opinions on which ecu is best. once you do the search you should be able to find the best ecu for your setup/ plans for the car.
edit: this thread is on the first page check it out.
https://honda-tech.com/zerothread?id=528640
Modified by 93preludevtec at 10:20 PM 6/12/2003
92LudeSI
Mar 29, 2005 04:45 PM
junlude19
Nov 2, 2004 03:45 PM
preludejdm
Feb 29, 2004 12:41 PM
chidoks
Jun 20, 2003 03:31 PM
chidoks
Jun 15, 2003 07:34 AM
