header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w00t! »</TD></TR><TR><TD CLASS="quote">17mm I believe. Lube it first, it will be tough to lossen. You might want to Lube the o2 sensor was well...
</TD></TR></TABLE> yeah, since its a "virgen" bolt itll give u a hard time....but dont give up my friend
do it the easy way and leave it attached at the header, but unplug it from its "socket" by the block.
Kinda hard to explain, dont take out the sensor, but unplug it on the other end, and push the wire through the hole.
Thats how I did mine, took 5 minutes.
go to your local auto store.. find an O2 sensor socket. it has a cut/opening to clear your wire coming out of the sensor. slap it on a rachet, get a bar on there for more torque and muscle it off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jun »</TD></TR><TR><TD CLASS="quote">I use the 22mm last week on my GSR</TD></TR></TABLE>
Yeah, It's either 17mm or 22mm...
Jmumblez2001
Jul 20, 2006 09:39 AM
2000psi
Sep 30, 2004 06:55 AM
integraautox
Sep 23, 2002 01:18 AM
