rear windshield wiper removal
i have search , and nothing came up
have seen a couple of post on this topic before .
i need the cap to cover the hole after the windshield wiper on the hatch is remove, does any one have the part # ?
also is it the same for integras as for ek hb , i would think so but just making sure .
I want to get the part before i remove it , other wise i would get stock with having a hole on the rear hatch
with tape
with tape
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon1 »</TD></TR><TR><TD CLASS="quote">I want to get the part before i remove it , other wise i would get stock with having a hole on the rear hatch
with tape
Thats what Im doing for now
. But I have something covering the hole with tape over that(hehehe-I dont care).
Anyway, Check http://www.SandMracing.com They have info and part numbers on there.
with tape
</TD></TR></TABLE>Thats what Im doing for now
. But I have something covering the hole with tape over that(hehehe-I dont care).Anyway, Check http://www.SandMracing.com They have info and part numbers on there.
I went to Home Depot and bought a elephant bolt?....... I believe is what someone on here called it.
elephant bolt, a few washers, wing nut, and some clear rtv worked like a charm for me. Only spent about 5 bucks also.
Just removed my wiper yesterday, you don't need to spend a dime on anything.
I grabbed the cap from the firewall, kinda ghetto but it fits. I used some superglue around the cap so it fits tight into the glass.
I like this better because it's not as retarded and bulky looking as the S&M one, it's pretty flush with the glass.
And here is the S&M racing one:
Modified by skafia at 11:43 AM 6/12/2003
Modified by skafia at 11:45 AM 6/12/2003
I know this is a long shot since I'm out of my territory, but does anyone know if these part numbers will coincide with the DC5/EP3? I'm in the same boat as most of you guys interested in this so any info would help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95redLUDE »</TD></TR><TR><TD CLASS="quote">I know this is a long shot since I'm out of my territory, but does anyone know if these part numbers will coincide with the DC5/EP3? I'm in the same boat as most of you guys interested in this so any info would help.</TD></TR></TABLE>
Not sure, only way to see is if you try it out...
I've done this the S&M racing way on my friends base RSX. Everything fits but you need to add washers under the rubber groumet because it's shorter than the ITR ones. You'll know what i am saying when you're doing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason »</TD></TR><TR><TD CLASS="quote">90301-SR3-000</TD></TR></TABLE>
thanks , i will be doing the removal this weekend .
im trying to put the hatch in a diet , and i will remove the most i can .
every bit counts
every bit counts
J.nguyen
Mar 18, 2007 02:30 PM
DarkSol97
Dec 23, 2006 11:24 AM
ek9tl
Jun 7, 2006 12:25 PM
