97-99 vs 00-01 ECU (GReddy Turbo Kit)
Old Jun 12, 2003 | 07:22 AM
RareSI's Avatar
Default 97-99 vs 00-01 ECU (GReddy Turbo Kit)
I've been reading recently about installation of the GReddy turbo kit. I see now that it's intended only for 97-99 and not 00 or 01, because of changes in the ECU (fuel mapping?).
I've seen a few people talk about aquiring a 97-99 ECU to be used on a 00-01 vehicle with the kit installed to prevent throwing codes.
Would there be any issues with a 97-99 vehicle running the 00 or 01 ECU?
In other words. Can a 97-99 owner and 00-01 swap ECUs without any problems?
Old Jun 12, 2003 | 07:46 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: 97-99 vs 00-01 ECU (RareSI)
if you buy my GReddy turbo kit, i'll give you my 97 ECU for you 00-01 ECU
Old Jun 12, 2003 | 07:57 AM
RareSI's Avatar
Default Re: 97-99 vs 00-01 ECU (Boosted97Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">if you buy my GReddy turbo kit, i'll give you my 97 ECU for you 00-01 ECU </TD></TR></TABLE>
It's not for me. A girl-friend of mine. She already has the kit.
So what's the answer to the question?
Old Jun 12, 2003 | 07:59 AM
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RareSI &raquo;</TD></TR><TR><TD CLASS="quote">
So what's the answer to the question?</TD></TR></TABLE>
couldn't tell ya, i've got a 97 model and i've been running AEM EMS since the kit went on the car, i don't have any experience with it
Old Jun 12, 2003 | 08:04 AM
sslude's Avatar
im ALMOST sure you can. but if its just fuel mapping, why not just a get an EMS or VAFC/SAFC? well good luck
Old Jun 12, 2003 | 08:09 AM
RareSI's Avatar
Default Re: 97-99 vs 00-01 ECU (sslude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sslude &raquo;</TD></TR><TR><TD CLASS="quote">im ALMOST sure you can. but if its just fuel mapping, why not just a get an EMS or VAFC/SAFC? well good luck</TD></TR></TABLE>
I am not positive it's fuel mapping. It's something I read yesterday while doing a search...
People were saying it throws code(s). But never listed which.
Old Jun 12, 2003 | 08:13 AM
sharkcohen's Avatar
Yes, you can put a 97-99 ecu into a 00-01 lude, several people have done this to run the stock Greddy kit on a 00-01. Alternatively, you could say screw the "blue box" and run hondata or AEM EMS, or if you want to keep your stock ecu intact, run EFI PMS.
Old Jun 12, 2003 | 08:16 AM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RareSI &raquo;</TD></TR><TR><TD CLASS="quote">People were saying it throws code(s). But never listed which.</TD></TR></TABLE>
Unfortunately, I've never heard a straight answer as to what code(s) came up running the kit on a 00-01. There 's always the possibility that it could be made to work if one knew what the problem was.
Old Jun 12, 2003 | 08:20 AM
RareSI's Avatar
Default Re: 97-99 vs 00-01 ECU (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you can put a 97-99 ecu into a 00-01 lude, several people have done this to run the stock Greddy kit on a 00-01.</TD></TR></TABLE>
This I know... I want to know if the opposite is true. Can the 00-01 ECU be run in the 97-99 ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">Alternatively, you could say screw the "blue box" and run hondata or AEM EMS, or if you want to keep your stock ecu intact, run EFI PMS.</TD></TR></TABLE>
We're trying to keep the cost down.
Old Jun 12, 2003 | 08:26 AM
Boostless97Lude
Guest
Posts: n/a
This I know... I want to know if the opposite is true. Can the 00-01 ECU be run in the 97-99 ?</TD></TR></TABLE>
WHAT!?!?!?!
i thought you just asked the opposite
Old Jun 12, 2003 | 08:33 AM
sharkcohen's Avatar
Sure, you can run the 00-01 ecu in a 97-99. However, you won't be able to run the Greddy turbo kit if you do.
Old Jun 12, 2003 | 11:54 AM
RareSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">Sure, you can run the 00-01 ecu in a 97-99. However, you won't be able to run the Greddy turbo kit if you do.</TD></TR></TABLE>
Hah. Obviously... But that's what I wanted to know. If there would be any other issues besides that.
customs-25
Mar 18, 2017 04:28 PM
Djin
Oct 31, 2002 06:01 PM
Kamasanga
Jul 26, 2002 09:22 AM
