What valves would be best to use?
i am currently building a N/A b16 and i want to use the skunk 2 flat faced valves to up the compression a little more. i just wanted to know if any of you guys out there have used these or if there is another flat faced valve that might be more sufficient than the skunk 2's, and what valve guides work with what valves the best with the least amount of wearing. just trying to get a few opinions before i blow more cash on my hoopty. all and any information is welcomed.
get either rev or supertech
the both offer flat face and are better quality than the skunk2
edit: after more research. rev flat faced valves are supertech
and i think skunk2 just get them from supertech as well.
i vote honda valves now or manley until I find more info....
Modified by Bob-DC2 at 7:05 PM 6/28/2003
OEM; ITR intake. Stock valves bend, aftermarkets break.... less detremental in the end if something happens. if you want compression, get pistons or a thinner headgasget....
nick
nick
go with the stock b16 valves all the b series exhaust valves r the same.
the type r valves r .5 grams liter then the b16 but u would be surprised to hear the b16 intake valves flow better then the itr valve
as long as the pistons dont come into contact with the valves u will never bend or break the stock stuff.
you will be amazed if u asked around how many fast guys still use the stock valves.
p.s the back cutted type r intake valve does not help flow what so ever. you will save a bunch of money i rather spend it on head work
the reason that i want the flat top valves is because when i match my combustion chambers with the 85mm bore of my block i dont want to lose any compression, so what imsaying is that i want the high compression valves to make up for the loss of deshrouding my combustion chambers. i just want to know what valves are good and which ones arn't. thanks for all the info people have already given
I've seen a few broken stock valves before, what happens is the heads fall of a kills yhe motor. Stainless Steel valves like REV valves wont brake. I've broken timing belts,broke cams but never broke a REV valves.
REV SS intake and exhaust here for 2+ years. No problems with them at all. I will use REV in my next motor too.
I ended up with the REV after my stock ITR ones started not sealing. The REVs have seen a little more mileage and much more abuse.
Jason
Jason
the supertech/skunk2 valves mushroom at the top because when they are used with a aftermarket Ti retainer that are designed to use the stock keeper, which is a cheap stamped steal piece and the valve will start to pull through the retainer as far as I know Ferrea is also the only company that offers a Ti retainer that Cannot be used with the stock keeper, the forge there own and are used also with a spring locater that is also way better than the stock one. I also don't like the design of some of these valves because on the exhaust side they have a sharp edge unlike the ferrea valve that has a rolled edge-which would help flow. Problem is I don't think they make a valve with the flat bottom, which is what you were looking for but I would make a sacrifice in compression for a gain in relability and more airflow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HEAD »</TD></TR><TR><TD CLASS="quote">the supertech/skunk2 valves mushroom at the top because when they are used with a aftermarket Ti retainer that are designed to use the stock keeper, which is a cheap stamped steal piece and the valve will start to pull through the retainer as far as I know Ferrea is also the only company that offers a Ti retainer that Cannot be used with the stock keeper, the forge there own and are used also with a spring locater that is also way better than the stock one. I also don't like the design of some of these valves because on the exhaust side they have a sharp edge unlike the ferrea valve that has a rolled edge-which would help flow. Problem is I don't think they make a valve with the flat bottom, which is what you were looking for but I would make a sacrifice in compression for a gain in relability and more airflow.
what do you think about type r valves?
why wouldnt you just go with higher compression pistons if you building the bottom end anyway??? besides, flat face valve give you only .04 comp gain at best, wouldnt make much difference anyway...
he had to decide whether to go 13:1 or 14:1, and since this is his daily driver he opted for the 13:1 since good gas is hard to get around here so he's looking for any little extra compression that he can get out of it over the 13:1.
q8delsol
Sep 7, 2006 03:18 PM
