steering rack rebuild worth it??
I'm in the process of doing mine, and I believe it's worth it.
Look at it this wayyou can either spend a hundred or more for a remanufactured rack. Or you can spen over 300 for a new one.
Or (my choice) spend about 30 bucks for all the stuff you need to rebuild yours.
Seems like an easy choice to me
there's a Honda dealership somewhere in Texas (someone posted the link before) that had an OE 88-91 civic/crx steering rack complete listed for ~$150-170.
someone post the link back up. i need to save it this time!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 »</TD></TR><TR><TD CLASS="quote">is it worth it? motor is out easy access to it. wut yall think?</TD></TR></TABLE>
Isnt still easy access with the motor in? Dont you just remove the lower header pipe and cat, pop off the tie rods and un bolt the 4 or 6 bolts to the rack and drop it? I think its easier to just buy a remanufactored one since you get new tie rods as well and its not much more
really u get new tie rods?? cuz im missing mine.. yeah i got quoted about 90 bux for a re manufactured 1. does it sound good?? with core of course
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoonHunter »</TD></TR><TR><TD CLASS="quote">Isnt still easy access with the motor in? Dont you just remove the lower header pipe and cat, pop off the tie rods and un bolt the 4 or 6 bolts to the rack and drop it?</TD></TR></TABLE>
yeah that is pretty much it except there is one bolt under the dash that holds the steering column to the rack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv »</TD></TR><TR><TD CLASS="quote">
yeah that is pretty much it except there is one bolt under the dash that holds the steering column to the rack.</TD></TR></TABLE>
but is it worth it? besides the fact that my car is 15 years old. I don't have much play in the steering, but it does follow ruts in the road like glue....if that makes any sence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman »</TD></TR><TR><TD CLASS="quote">but it does follow ruts in the road like glue....if that makes any sence.
that's your tires, not the steering.
</TD></TR></TABLE>that's your tires, not the steering.
Does anyone know the dealer that sold OE racks for only $150-170? I need one also, and I'd much rather buy OEM than a reman from autozone or advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoonHunter »</TD></TR><TR><TD CLASS="quote">Isnt still easy access with the motor in? Dont you just remove the lower header pipe and cat, pop off the tie rods and un bolt the 4 or 6 bolts to the rack and drop it? I think its easier to just buy a remanufactored one since you get new tie rods as well and its not much more</TD></TR></TABLE>
Don't forget about removing your shift linkage from your transmission and you will need a "Punch" to knock out the cotter pin. AFter you drop your cat and lingages the rack will then fall down. In most cases you will need a "ball joint seperator".
GSRCRXsi
18
Oct 11, 2011 06:00 AM
hatcht9x
22
Jun 26, 2008 11:28 AM
pitchblacksol
Welding / Fabrication
22
Nov 15, 2007 10:47 PM
