Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
tie rod locknut...help
Old Jun 11, 2003 | 06:49 PM
REDMAN1322's Avatar
New User
Default tie rod locknut...help
help ive been trying to loosen the tie rod locknut so i can adjust the toe,
but that dam thing wont budge
ne one else have this problem
ne advice would be very helpful, thanks
Old Jun 11, 2003 | 06:58 PM
743 Stunna's Avatar
Default Re: tie rod locknut...help (REDMAN1322)
breaker bar.
Old Jun 11, 2003 | 07:06 PM
REDMAN1322's Avatar
New User
Default Re: tie rod locknut...help (743motorsport)
is that how u loosened it
Old Jun 11, 2003 | 07:12 PM
.RJ's Avatar
.RJ
yes. and elbow grease. I have a section of steel pipe i use as a cheater/breaker.
Old Jun 11, 2003 | 07:15 PM
REDMAN1322's Avatar
New User
Default Re: tie rod locknut...help (.RJ)
how big of a pipe u use
Old Jun 11, 2003 | 07:30 PM
.RJ's Avatar
.RJ
my pipe is really big
Old Jun 11, 2003 | 07:32 PM
REDMAN1322's Avatar
New User
how high r u jacking up the car, cause i was just using the stock jack, so all i could get in there was athe freakin wrench
Mike_C's Avatar
don't flatter yourself. i'm sure katie calls you "little ry ry" for a reason.
Old Jun 11, 2003 | 07:35 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDMAN1322 &raquo;</TD></TR><TR><TD CLASS="quote">how high r u jacking up the car, cause i was just using the stock jack, so all i could get in there was athe freakin wrench
Invest in one of these
http://www.harborfreight.com/c...47246
Evan55's Avatar
Default Re: (JMU1337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMU1337 &raquo;</TD></TR><TR><TD CLASS="quote">don't flatter yourself. i'm sure katie calls you "little ry ry" for a reason.</TD></TR></TABLE>
0wn3d
(just like this thread)
Old Jun 11, 2003 | 07:37 PM
REDMAN1322's Avatar
New User
k thaNKS
Old Jun 12, 2003 | 12:35 PM
MrBite's Avatar
Breaker bar, as has been said, and whack it (the breaker bar) with a big-*** hammer a few times. Also soak in in WD-40/PB Blaster/your lubricant of choice for a little while, see if that helps.
Old Jun 12, 2003 | 06:08 PM
IN VTEC's Avatar
19mm and 22mm open-ends and a hammer to break the 22mm nut loose.
a267mm
Welding / Fabrication
Mar 20, 2016 07:15 PM
White_EG1
17
Oct 19, 2015 06:52 PM
BIGef
20
May 5, 2013 03:38 PM
teewhy55
Aug 28, 2005 03:41 PM
Urban Business
Apr 16, 2003 04:39 PM
