used arp head studs?
Old Jun 11, 2003 | 06:25 PM
aira
Guest
Posts: n/a
Default used arp head studs?
i plan to put together a ls/vtec motor and i came upon a used set of arp head studs. so i was wondering if it's ok to use *used* arp head studs. also how can you tell if it's real arp head studs and not stock oem head studs? thanks.
Old Jun 11, 2003 | 06:54 PM
TrboInteg's Avatar
Default Re: used arp head studs? (jdm aira)
Dude, they aren't that expensive. Just get new ones, they're only $120. And at that price, why take the risks.
Old Jun 11, 2003 | 07:15 PM
MikeMAN's Avatar
ARP head studs are like 100000000000000000000000000000000000000000x less likely to stretch than stock ones and I have seen people re-use stock ones. Most people buy ARP's because they can be reused + they are very very strong. I would say, buying new ones or replacing them everytime u took off the head would be a large waste of $$$.
mike
Old Jun 11, 2003 | 08:48 PM
Flamenco-T's Avatar
Default Re: used arp head studs? (MikeMAN)
ARP can be re-used over and over again.
ARP is a Stud, stock is a Bolt, those are the difference.
stan
Old Jun 11, 2003 | 08:58 PM
aira
Guest
Posts: n/a
Default Re: used arp head studs? (Flamenco-T)
ok i have one more question. i have a b16 head but the studs he got are for the gsr. will it be ok to use those on my b18a block because i heard you're supposed to get the studs that are for your head. (ex. b16 head; b16 head studs)
Old Jun 11, 2003 | 10:26 PM
giooooo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm aira &raquo;</TD></TR><TR><TD CLASS="quote">ok i have one more question. i have a b16 head but the studs he got are for the gsr. will it be ok to use those on my b18a block because i heard you're supposed to get the studs that are for your head. (ex. b16 head; b16 head studs)</TD></TR></TABLE>
i got a b16 head on a b18a1 block i used arp gsr head studs they work fine but i got a stupid oil leak thou i gotta retorque my head. car runs fine but a stupid oil leak the wonderful world of the ls/vtec
Old Jun 11, 2003 | 11:31 PM
ALLMTRWHORE's Avatar
Default Re: used arp head studs? (Giovannie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Giovannie &raquo;</TD></TR><TR><TD CLASS="quote">
i got a b16 head on a b18a1 block i used arp gsr head studs they work fine but i got a stupid oil leak thou i gotta retorque my head. car runs fine but a stupid oil leak the wonderful world of the ls/vtec</TD></TR></TABLE>
haha welcome! now! recheck everything and make sure you have not stripped stuff! it is well aluminum! arp is good ****!
Old Jun 12, 2003 | 07:38 PM
giooooo's Avatar
Default Re: used arp head studs? (ALLMTRWHORE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMTRWHORE &raquo;</TD></TR><TR><TD CLASS="quote">
haha welcome! now! recheck everything and make sure you have not stripped stuff! it is well aluminum! arp is good ****! </TD></TR></TABLE>
its actually leaking from the headgasket under the distributor side but the timing belt side there is no leak im thinking its the stupid plug but i doubt it.. how can a leaking head gasket make the motor run good? my car idles at 700
Old Jun 12, 2003 | 09:26 PM
aira
Guest
Posts: n/a
its actually leaking from the headgasket under the distributor side but the timing belt side there is no leak im thinking its the stupid plug but i doubt it.. how can a leaking head gasket make the motor run good? my car idles at 700 </TD></TR></TABLE>
take our the dizzy and get some silicone to seal it up. that should do the trick. or it make be your cam seal.
Old Jun 12, 2003 | 11:58 PM
giooooo's Avatar
take our the dizzy and get some silicone to seal it up. that should do the trick. or it make be your cam seal.</TD></TR></TABLE>
its not the dizzy nothign is leaking from there not my cam seal neither its leaking right where the head mates to the block (dizzy side)
Old Jun 13, 2003 | 01:12 AM
aira
Guest
Posts: n/a
maybe your head or block may be warped? go get it decked or something.
PhrequenC
Jun 9, 2008 10:55 AM
sacjdmz
Oct 15, 2006 11:17 AM
9seccivicsi
Sep 20, 2004 10:55 AM
Turboteggy
Jan 14, 2004 04:17 AM
baonest1
Oct 17, 2002 06:29 PM
