Intermitant Battery light...
Old Jun 11, 2003 | 06:23 PM
Alexnaderkeith's Avatar
Default Intermitant Battery light...
90crx Si, ZC engine, pm6 ECU.
Light will flash for 1/2 a second, then shut off.
what would cause this? bad battery/alternator?
battery is 5 months old, I have no stereo, but I've been driving with my highbeams on a hell of alot...
any ideas?
Old Jun 11, 2003 | 07:53 PM
chhuong's Avatar
Default Re: Intermitant Battery light... (Alexnaderkeith)
alternator going bad!! Basically the battery light is a warning light for your alternator telling you it's going out!!
Old Jun 11, 2003 | 08:05 PM
CRXRageD's Avatar
Default Re: Intermitant Battery light... (chhuong)
Yup sounds like your alternators dying.
Old Sep 7, 2003 | 04:52 PM
Shawn C's Avatar
In The Garage
Default Re: Intermitant Battery light... (CRXRageD)
bringin the thread back from the dead, i am having this same problem, but my car has a full charge. new battery, but the alternator is older. never had a single problem until today. when i hit a bump, it flashes on and off. i played with the connector, and it still did the same thing. any suggestions?
Old Sep 10, 2003 | 12:47 AM
Tyson's Avatar
Default Re: Intermitant Battery light... (22lbGS-R)
loose belt, or just alt going bad.
"battery" light is a misnomer, it indicates the health of the charging system, not the voltage of the battery.
Old Sep 10, 2003 | 08:32 AM
tpr's Avatar
tpr
Default Re: Intermitant Battery light... (Tyson)
Its the brushes in the alternator. They have reached the end of there travel in the brush holder. Take it to a good alternator shop and they will ususally pop a set in for under $20. I have a spare set because when i saw how easy it is to replace them i just bought a new set ($6) so i can do the job next time. Or you can buy a lifetime alternator and when it goes bad just swap for a new one.
meelow
Apr 29, 2010 09:35 PM
haywyre
Oct 9, 2008 12:27 PM
Starbucks_91b16acrx
Oct 15, 2003 11:27 PM
fe519
Sep 23, 2003 03:25 AM
