Help: I screwed up the install of the Type R swaybar....
Old Jun 11, 2003 | 05:52 PM
anjapower's Avatar
Default Help: I screwed up the install of the Type R swaybar....
So I go to install the DC5R swaybar on my car tonight with the help of my friends. I had read enough on EPhatch to know what to do. To keep the bolt and the nut spinning together, I used a 5mm allen wrench to keep the bolt in place.
However, since the nut requires so much force to turn it, I resorted to prying the allen wrench and the 14mm wrenches apart from each other. This resulted in the allen wrench slipping out from its hole 3 times or so...thus the hole is now stripped. I can't think of anyway to turn the nut off without having an allen wrench in that hole.
I tried a 6mm wrench but that was too big. What do you guys think I should do? I'm gonna take it to my mechanic tomorrow to address this situation but was wondering if there's anything I can do in the meantime. Also is it dangerous to drive around with nut on one end of the swaybar off halfway?
Please HELP!!!!
Old Jun 11, 2003 | 07:04 PM
.RJ's Avatar
.RJ
Default Re: Help: I screwed up the install of the Type R swaybar.... (anjapower)
Vice Grips
Old Jun 11, 2003 | 07:46 PM
anjapower's Avatar
Default Re: Help: I screwed up the install of the Type R swaybar.... (.RJ)
quite a tight space, i don't think that would work.
Old Jun 11, 2003 | 08:00 PM
.RJ's Avatar
.RJ
There's always room for vicegrips. Get creative.
Old Jun 11, 2003 | 08:12 PM
diewX3's Avatar
Push comes to shove I'd disconnect the endlinks. Were you taking the bolt off or putting it back on? I'm in a hurry right now so I didnt get to read it all. But yeah that/s my advice get new endlinks if it is stripped so bad
Old Jun 11, 2003 | 08:16 PM
anjapower's Avatar
Default Re: Help: I screwed up the install of the Type R swaybar.... (diewX3)
i was trying to take it off. I'm thinking that I should probably hit up the honda dealer first thing tomorrow morning...
Old Jun 11, 2003 | 08:20 PM
NONKonformyst's Avatar
Try finding someone with a tap and die set and re-tap the hole. I think you might even be able to rent them out at some tool and auto stores.
Good luck!
Old Jun 12, 2003 | 05:59 AM
t o m's Avatar
melt it off with a torch or try using a dremel and cut that sucka out and find a new screw
HGZ
Oct 9, 2004 09:23 PM
JFG Kevin
Jun 29, 2004 03:45 PM
sjteg
Jan 29, 2004 11:57 AM
RineRacing
10
Apr 4, 2002 03:06 PM
95excoupe
Jan 27, 2002 10:12 AM
