washer trick
Old Jun 11, 2003 | 05:40 PM
bearboy80's Avatar
Default washer trick
I did research but could not find why people are not doing washer trick for front to fix camber. It does not work or it's for safty reason?
Old Jun 11, 2003 | 05:46 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: washer trick (bearboy80)
No worky, jerky.
Old Jun 11, 2003 | 05:59 PM
bearboy80's Avatar
Default Re: washer trick (SkyeC)
for rear, what size of washer do i need to fix about 1.5 degree?
Old Jun 11, 2003 | 06:01 PM
ek_will's Avatar
just get a couple of 3/8 washers, gota use trial and error i guess to see how many u really need
Old Jun 11, 2003 | 06:03 PM
sshaikh01's Avatar
I'm using four 3/8 washers from home depot on the rear of my car.
I think it helped.
Old Jun 11, 2003 | 06:36 PM
bearboy80's Avatar
Default Re: washer trick (sshaikh01)
for front, do you guys like skunk2 style(changing whole LCA) or SPC style? Which one will work better?
A guy from local tire shop said that welding is involved to install SPC camber kit therefore i can't install it myself(He wanted $140 for installation). Is it true? cuz i read everyone in this board installing their camber kit by themselves. BTW it's for 95 del sol.
Old Jun 11, 2003 | 06:39 PM
VTEC-DA's Avatar
You dont need to weld, there are bolts holding it in place.
Old Jun 11, 2003 | 06:42 PM
Yokohama's Avatar
Default Re: washer trick (VTEC-DA)
I have had washers in the rear of my Si for 3 years now and no probs!
Old Jun 11, 2003 | 06:52 PM
bearboy80's Avatar
what's the difference b/w ingalls or the spc ball joints style vs. full uca replacement like skunk2? What's the advantage of one over the other?
Old Jun 11, 2003 | 06:56 PM
Synergy001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearboy80 &raquo;</TD></TR><TR><TD CLASS="quote">for front, do you guys like skunk2 style(changing whole LCA) or SPC style? Which one will work better?
A guy from local tire shop said that welding is involved to install SPC camber kit therefore i can't install it myself(He wanted $140 for installation). Is it true? cuz i read everyone in this board installing their camber kit by themselves. BTW it's for 95 del sol.</TD></TR></TABLE>
Thats not true about the SPC ones because I just did mine myself this weekend and I didnt do any welding. It was a bitch getting the stock one out tho since i didnt have a ball joint compressor or whatever tool you need to take it off. I just hammered it until it came out...LOL...
Old Jun 11, 2003 | 07:07 PM
bearboy80's Avatar
Default Re: washer trick (Synergy001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synergy001 &raquo;</TD></TR><TR><TD CLASS="quote">
Thats not true about the SPC ones because I just did mine myself this weekend and I didnt do any welding. It was a bitch getting the stock one out tho since i didnt have a ball joint compressor or whatever tool you need to take it off. I just hammered it until it came out...LOL...</TD></TR></TABLE>
can you please tell what do i need to do to install them? because i need to do it this weekend. thanks
Old Jun 11, 2003 | 07:35 PM
PSU's Avatar
PSU
formerly DxHatchback
so only washers are needed? last time i used different screws and washers
Old Jun 11, 2003 | 07:57 PM
Mugen Hamster's Avatar
can you please tell what do i need to do to install them? because i need to do it this weekend. thanks</TD></TR></TABLE>
All you need is a couple of hand-wrenches. No biggie. Like 15 min install.
Old Jun 11, 2003 | 07:58 PM
PSU's Avatar
PSU
Default Re: washer trick (AntiRice Superstar)
are longer bolts required to install 3 or 4 washers?
Old Jun 11, 2003 | 08:01 PM
andrew dc's Avatar
Default Re: washer trick (DxHatchback)
I have the stock bolts with 3 washers. I hear the rule of thumb is 1 washer for every .5 degrees.... trial in error.. anything more than 3, it is strongly recomended to lengthen the bolt...
Old Jun 11, 2003 | 08:04 PM
PSU's Avatar
PSU
Default Re: washer trick (CRX25)
yeah i figured that
i have measurements in my room
i had the bolts, removed them for my 17"s, misplaced em
Old Jun 11, 2003 | 08:23 PM
bearboy80's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AntiRice Superstar &raquo;</TD></TR><TR><TD CLASS="quote">
All you need is a couple of hand-wrenches. No biggie. Like 15 min install.</TD></TR></TABLE>
why you need ball joint compressor for then? What did you have trouble with to get it out?
I hear the rule of thumb is 1 washer for every .5 degrees.</TD></TR></TABLE>
what size of washer for every .5 degree?
Aftermath_Hatch
51
Dec 17, 2009 08:27 AM
zimzim
Mar 25, 2008 03:52 PM
Flux
Jun 9, 2003 05:10 PM
mon2mon2
Aug 31, 2002 03:19 AM
Turbo B16A SI
Mar 28, 2002 08:23 PM
