washer trick
washer trick
I did research but could not find why people are not doing washer trick for front to fix camber. It does not work or it's for safty reason?
Re: washer trick (sshaikh01)
for front, do you guys like skunk2 style(changing whole LCA) or SPC style? Which one will work better?
A guy from local tire shop said that welding is involved to install SPC camber kit therefore i can't install it myself(He wanted $140 for installation). Is it true? cuz i read everyone in this board installing their camber kit by themselves. BTW it's for 95 del sol.
Re: washer trick (SkyeC)
what's the difference b/w ingalls or the spc ball joints style vs. full uca replacement like skunk2? What's the advantage of one over the other?
Re: washer trick (bearboy80)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearboy80 »</TD></TR><TR><TD CLASS="quote">for front, do you guys like skunk2 style(changing whole LCA) or SPC style? Which one will work better?
A guy from local tire shop said that welding is involved to install SPC camber kit therefore i can't install it myself(He wanted $140 for installation). Is it true? cuz i read everyone in this board installing their camber kit by themselves. BTW it's for 95 del sol.</TD></TR></TABLE>
Thats not true about the SPC ones because I just did mine myself this weekend and I didnt do any welding. It was a bitch getting the stock one out tho since i didnt have a ball joint compressor or whatever tool you need to take it off. I just hammered it until it came out...LOL...
Re: washer trick (Synergy001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synergy001 »</TD></TR><TR><TD CLASS="quote">
Thats not true about the SPC ones because I just did mine myself this weekend and I didnt do any welding. It was a bitch getting the stock one out tho since i didnt have a ball joint compressor or whatever tool you need to take it off. I just hammered it until it came out...LOL...</TD></TR></TABLE>
can you please tell what do i need to do to install them? because i need to do it this weekend. thanks
can you please tell what do i need to do to install them? because i need to do it this weekend. thanks</TD></TR></TABLE>
All you need is a couple of hand-wrenches. No biggie. Like 15 min install.
Re: washer trick (DxHatchback)
I have the stock bolts with 3 washers. I hear the rule of thumb is 1 washer for every .5 degrees.... trial in error.. anything more than 3, it is strongly recomended to lengthen the bolt...
Re: washer trick (AntiRice Superstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AntiRice Superstar »</TD></TR><TR><TD CLASS="quote">
All you need is a couple of hand-wrenches. No biggie. Like 15 min install.</TD></TR></TABLE>
why you need ball joint compressor for then? What did you have trouble with to get it out?
I hear the rule of thumb is 1 washer for every .5 degrees.</TD></TR></TABLE>
what size of washer for every .5 degree?
Turbo B16A SI
03-28-2002 08:23 PM
