wireharness for JDM B16a SIR2 going into '92 CX
Old Jun 11, 2003 | 05:10 PM
VWkila's Avatar
Default wireharness for JDM B16a SIR2 going into '92 CX
Which one should I get? I'm thinking '99 si ones.
Old Jun 11, 2003 | 05:13 PM
Lysawy's Avatar
Default Re: wireharness for JDM B16a SIR2 going into '92 CX (VWkila)
since your too lazy to check your car should already be wired for vtec the only two things you gonna have to do is add knock sensor wire and transfer wires from another side b/c its JDM they have battery at the right side...
Old Jun 11, 2003 | 05:25 PM
VWkila's Avatar
Default Re: wireharness for JDM B16a SIR2 going into '92 CX (Lysawy)
CX already comes with VTEC wire?
Old Jun 11, 2003 | 06:33 PM
B16b2b's Avatar
jeez....you do not have a vtec wire in a cx...you couldn't tell?
howabout trying a 92-95 civic si harness. or maybe even a 94-95 gsr dohc vtec harness.
i guess the search was disabled.....
Old Jun 11, 2003 | 07:04 PM
nsxmatt's Avatar
Use your stock CX harness and run the vtec wires, knock, and o2 to the ecu. You could also use a 92-95 civic si/ex harness and save the vtec wires but at a added cost.
Old Jun 11, 2003 | 07:28 PM
EGsixer's Avatar
Default Re: wireharness for JDM B16a SIR2 going into '92 CX (nsxmatt)
yea just use your stock harness and add the neccessary wires. thats why i did.
Old Jun 11, 2003 | 10:44 PM
Lysawy's Avatar
Default Re: wireharness for JDM B16a SIR2 going into '92 CX (EGsixer)
92 civics are wired for vtec , can someone check on that with 92 dx or cx and let me know .... cuz i know 93-95 didn't have vtec wires...
Old Jun 12, 2003 | 12:46 AM
Kusai.Nihonjin.Desu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lysawy &raquo;</TD></TR><TR><TD CLASS="quote">92 civics are wired for vtec , can someone check on that with 92 dx or cx and let me know .... cuz i know 93-95 didn't have vtec wires...</TD></TR></TABLE>
I didn't need a new harness. I was told that the 92 CX's that were made in Canada came VTEC ready. Er...I think all 92 CX's were made in Canada. But anyways.
Old Jun 12, 2003 | 03:46 AM
nsxmatt's Avatar
Default Re: wireharness for JDM B16a SIR2 going into '92 CX (Shmoo)
Yes the harness you plug into at the shock tower is wired for vtec on all 92 Civics but the engine harnesses are different. Only the si/vx harness will have the vtec plugs. Bet bet will to use your stock harness on the new motor. It won't have plugs for vtec but you can steal the plugs of of the cut b16's harness and run the wires to the ecu.
Old Jun 12, 2003 | 05:16 AM
VWkila's Avatar
I guess I'll just add the VTEC wires than. I hope this isn't too difficult.
Old Jun 12, 2003 | 05:46 AM
dogpile5's Avatar
25 Year Member
that model should be wired already from what i've seen. your stock harness will work just fine. if you don't know how to add 4 wires to your harness, you may want to consider having someone who has done it before help you out during your swap.
Old Jun 12, 2003 | 08:39 AM
Jonny G.'s Avatar
I have a JDM B16A SiR II in my '92 CX as well. Since VTEC is already wired into the engine bay harness all I used was an engine harness off a '92 Si/EX and just added the knock-sensor wire. Use that harness and just add ONE wire, that's all it takes.
Old Jun 12, 2003 | 09:06 AM
redline201's Avatar
Default Re: wireharness for JDM B16a SIR2 going into '92 CX (Jonny G.)
i was under the impression that all 92 civic were wired for vtec
Old Jun 12, 2003 | 09:17 AM
Mike banX's Avatar
is a 93 cx wired for vtec if its manufactured in canada?
Old Jun 12, 2003 | 09:33 AM
Sketch_hs's Avatar
Default Re: (Mike banX)
what about a 93 DX. how do you wire it for vtec? the BEST way.
-Sketch
Eric724
Apr 12, 2011 05:39 PM
stealth_EK4
May 5, 2005 08:09 AM
rdaggett
Mar 8, 2005 09:09 AM
SLowCrx
Dec 16, 2003 02:27 PM
89EF9
Dec 10, 2003 04:46 AM
