opinions
Old Jun 11, 2003 | 12:17 PM
GReddy SI's Avatar
Default opinions
I have a b16a2 in my vx, with I/E/H p28chipped
now my redline is 8500
and i am planning to get a nx kit 50shot,
would it be safe to rev to 8500 on the bottle
on a stock head?
or i should order a custom chip with a stock b16
maps and fuel cut off
Old Jun 11, 2003 | 01:31 PM
EVIL Hx Coupe's Avatar
Default Re: opinions (GReddy SI)
I'd rechip with a stock redline just to be safe....
Old Jun 11, 2003 | 01:44 PM
ERA's Avatar
ERA
Even though you only plan on doing a 50 shot I wouldn't suggest going that high on the RPM band. When you start running it, see where it stops making power through the gears. Key here is consistancy which really requires your pressure to stay constant and not to hit any dry spots in the line. Def. get a gauge and depending how far you wanna go, a bttl warmer isn't a bad investment either. You will probably see that you won't be taking your car much further than 76-7800 rpms anyway for the best results. My motor on bttl with the p28 skunk2 pgm redlines at 9500 but I've never taken it past 7600. especially when my head was stock, not a good idea, anyone here will tell you that. if you got the loot, upgrade to just springs retainers and a mild cam. that will be worth the money and save you from floating valves easily to 8500. Remember, that **** gets real lean that high to so upgrade your fuel pump and inline **** to accomodate.
Old Jun 11, 2003 | 09:33 PM
GReddy SI's Avatar
Default Re: opinions (delslo26)
sweet thanx for the tips
Old Jun 11, 2003 | 10:06 PM
mugensport9's Avatar
ya that is great information.
its all about head work
2wheelhunter
Aug 15, 2006 07:06 PM
CRXstress
41
Jan 23, 2006 03:39 PM
Crimson_Tide
Nov 4, 2005 08:32 AM
civhatchsi
Apr 21, 2003 02:43 PM
brasilracing
28
Nov 29, 2002 05:27 PM
