rattling noise around 3000rpm?
I have 2 friends who have gs-r's and both had a problem with a rattling noise around 3000rpm. Took off all heatshields and such but cant figure out what it is,
anyone got an idea?
anyone got an idea?
yep. prolly the a-pipe. It has an inner pipe that when it comes loose vibrates with the outer piping. People either weld it or get a new header.
new header will solve the problem.......i think most integra owners go through that rattling noise becuase I went through it also, bought headers and rt cat, no rattling.
See part #6? That's the problem. It's impossible to remove without taking the whole exhaust manifold off. Might as well wait until you get an aftermarket header.
Your A-pipe is the problem. Go to your acura dealer. They replaced mine for free under warranty (saved $400). If i remember correctly your warranty on exhaust is 60k miles.
Modified by BlkGSR at 6:45 PM 6/11/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp »</TD></TR><TR><TD CLASS="quote">See part #6? That's the problem. It's impossible to remove without taking the whole exhaust manifold off. Might as well wait until you get an aftermarket header.
I took mine off while it was on :/ sawzall and 14 inch blade
</TD></TR></TABLE>I took mine off while it was on :/ sawzall and 14 inch blade
I had that same problem.... it was my cat though and when I got a new one it went away
CHANGE THAT..... I Also got a header at the same time so, the rest of you are probably right.
i have the same problem with my gsr.
