What octane gas do you guys use on ur ZC or B16a??
Old Jun 11, 2003 | 11:29 AM
crxtreme27's Avatar
Default What octane gas do you guys use on ur ZC or B16a??
At stock timing, is 87 octane still ok to use on both motors??
just a question, i searched but had no luck..
thanks
Old Jun 11, 2003 | 11:31 AM
bossman032's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (crxtreme27)
I think only vtec motors need high octane gas.
thats my 2cents
Old Jun 11, 2003 | 11:53 AM
raene's Avatar
I run 92 octane on stock timing, 94 octane with 2 degrees advanced. I tried 94 with 4 degrees advanced but got preignition at 7800+ rpm.
Old Jun 11, 2003 | 01:05 PM
keithv's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (raene)
i run 89 octance in my zc, but i don't think i really need to. i'd don't drive it that much and i had rebuilt it 5,000 miles ago, so i went on the conservative side.
Old Jun 11, 2003 | 01:08 PM
Denny317's Avatar
i used 89 on my n/a zc setup..then 93+ when it was turbocharged.
Old Jun 11, 2003 | 01:40 PM
90civichbsi's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (Denny317)
93 in my b16
Old Jun 11, 2003 | 02:20 PM
Brandon Chun's Avatar
I wouldnt use 87 on a b16 it will run like crap. Compression is high get the good stuff.
Old Jun 11, 2003 | 02:42 PM
Patch's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (Brandon Chun)
93 on my B16, with a buttload of timing advance from my Spoon chip. I wouldn't use 87, just because it may spark knock a little and the computer would retard your timing, costing you HP.
Old Jun 11, 2003 | 07:04 PM
DJ_SaNdOz's Avatar
i use 93 octane on my zc b/c i figure in japan they don't use low octane gas, so the engine was probably designed w/ something better than 87 in mind.
Old Jun 11, 2003 | 07:17 PM
MisterB's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (DJ_SaNdOz)
i run 91 in my b16a compression is a tad over 11:1 timing at 0,0
i would run higher octane but in cali 91 is all we got
Old Jun 11, 2003 | 07:25 PM
drjondurst's Avatar
91 on my n/a ZC.. 93 daily and maybe more at the track when its boosted.
BTW check my sig and someone buy my slicks so I can actually get it boosted!
Old Jun 11, 2003 | 07:26 PM
1st-hybrid's Avatar
Well I don't have either of those engines, but I thought I'd contribute anyways.
I run either 93 or 94 in my b18c.
I believe that the b16 is supposed to run on premium, but 87 shouldn't effect it negativley.
Old Jun 11, 2003 | 07:41 PM
FourthGenHatch's Avatar
94 on my ZC.
Old Jun 11, 2003 | 08:57 PM
crxtreme27's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (FourthGenHatch)
damn bay area, the highest octane i have seen around is 91.....
Old Jun 11, 2003 | 09:31 PM
pokemon's Avatar
I use 93 on everything from a d15 to a b18c
Old Jun 11, 2003 | 09:44 PM
MADEINIRAQ's Avatar
Default Re: (pokemon)
93
b16
Old Jun 11, 2003 | 10:16 PM
incubus's Avatar
Default Re: (madeiniraq)
93-94 in my b16a.
think I am going to try 102 when I fill up next to see if it runs any better.
Old Jun 11, 2003 | 10:19 PM
incubus's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">I think only vtec motors need high octane gas.
thats my 2cents </TD></TR></TABLE>
nahh, a d16z6 or y8 doesnt need high octane.
as a general rule of thumb just follow what the tach says (or the tach in the car the motor came in said) ie: unleaded fuel only or premium unleaded only, cant go wrong that way.
Old Jun 11, 2003 | 10:40 PM
nikitad's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (incubus)
87 on the ZC. Didn't have any problems in 2 years.
88ZCRX's Avatar
93 all the time. As soon as I'm turbo I will probably mix in a little turbo blue(110) with every fill up. When I get something that will control my timing I might bump it back down to just 93.
Old Jun 11, 2003 | 11:22 PM
JohnysZC's Avatar
im in the same boat 91 for my boosted ZC runs excellent. I'll see how well it runs next week on the Dyno.
Old Jun 11, 2003 | 11:54 PM
blah13's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (JohnysZC)
89 on my zc, no probs but also no advanced timing etc...
Old Jun 12, 2003 | 03:52 AM
crxste's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (blah13)
I run 95 Octane most of the time but sometimes i run 98 octane as it's just straight pump gas over here in the UK
Old Jun 13, 2003 | 08:41 PM
incubus's Avatar
Default Re: What octane gas do you guys use on ur ZC or B16a?? (crxste)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxste &raquo;</TD></TR><TR><TD CLASS="quote">I run 95 Octane most of the time but sometimes i run 98 octane as it's just straight pump gas over here in the UK</TD></TR></TABLE>
by the way how many pounds do you pay for a Liter(is that what it is sold in) of 95 octane in the U.K.?
Old Jun 14, 2003 | 01:55 AM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re: (incubus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubus &raquo;</TD></TR><TR><TD CLASS="quote">think I am going to try 102 when I fill up next to see if it runs any better.</TD></TR></TABLE>
May I ask why you think your car will "run better" on 102 Octane?
tsdenny
Aug 21, 2004 01:55 PM
SiB16A
57
Sep 15, 2003 02:17 AM
kyle h.
Apr 2, 2003 09:01 AM
CivicBoi
52
Mar 6, 2003 08:17 PM
ScottEK
Jan 5, 2003 07:41 PM
