rsx ride problem
just lowered my roomates rsx with groundcontrols. it ride's pretty nice but went it hit a little bump in the street it hits pretty god damn hard like your struts are out? any help anyone?i thought it was the tire pressure but that is not the problem. thanks
does it make a noise...like a "clank" noise? Or does it just hit hard like its bottoming out..if its the second...then you forgot to cut the bumpstops which explains why the car feels like its bottoming out over small bumps...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arcticblursx »</TD></TR><TR><TD CLASS="quote">does it make a noise...like a "clank" noise? Or does it just hit hard like its bottoming out..if its the second...then you forgot to cut the bumpstops which explains why the car feels like its bottoming out over small bumps...</TD></TR></TABLE>i think it's the second one, but groundcontrol came with a triangle bumpstop lookin thing i'm not sure if that it. And if you bottoming out are the strut bad already?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4 fa sho »</TD></TR><TR><TD CLASS="quote">i think it's the second one, but groundcontrol came with a triangle bumpstop lookin thing i'm not sure if that it. And if you bottoming out are the strut bad already?</TD></TR></TABLE>
I dont quite understand what your saying here...ok, so the ground controls came w/ a triangle bumpstop...so you got rid of your OEM one though then right? that dust boot cover contains the bumpstop... your second question...are you asking if the car is bottoming out then that means the strut is bad right? well..depends on the amount of mileage..unless he has like 50k miles on his stock shocks/struts then they could be out..only one way to find out though...jack up the front and see if the wheels fall..if they do, that means that the struts still have pressure and that they're not leaking or blown...
Im pretty sure it has someting to do w/ the bumpstops...the grouncontrols are just adjustable coilovers...what im thinking is that since theyre not a whole damper/coilover set...that means that when you put back the front shock assembly you a) did not replace the OEM one w/ the one provided from ground control or b) do not need the one provided from GC but you do need to trim at least .6 of an inch off the oem bumpstop...
i didn't put the oem one back. i only the triangle bumpstop lookin thing the gc provided. are you suppose to put the oem one's back? i was looking oem they cover the strut so am i suppose to cut off the cover can use the oem bumpstop? forgot to mention that gc only provided a rubber bushing(part that go's on top of the spring portion) only for the rear and for the front they didnt provided the bushing....
depending on the instructions..once you put on your OEM dustboot w/ bumpstop in it back on..and its still creating a noise like your bottoming out..then you'll have to cut the bumpstop from the dust boot and trim roughly .5 of an inch off it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arcticblursx »</TD></TR><TR><TD CLASS="quote">depending on the instructions..once you put on your OEM dustboot w/ bumpstop in it back on..and its still creating a noise like your bottoming out..then you'll have to cut the bumpstop from the dust boot and trim roughly .5 of an inch off it....</TD></TR></TABLE>thanks for all this help. no i didn't the oem dustboot/bumpstop back on. i think thats the problem. hopefully it didn't damage the struts or anything. i'll let you know if it works or not.
also check torque specs....check the self locking nut on top of the oem strut w/ the GC's...if theyre on too tight it might not allow the spring enough travel so it'll keep bottoming out...Im pretty sure your problem is because you didnt install the bumpstops....if the fronts do not have ANY kind of bumpstop in it..then thats your problem...bumpstops keep the car from bottoming out and I think thats whats happening to your friends car...
portaman03
Feb 15, 2008 08:33 AM
Window_Shopper
14
Dec 7, 2005 04:26 PM
