which bushings squeak on my rear suspension?
Old Jun 11, 2003 | 10:27 AM
juniordc2's Avatar
Default which bushings squeak on my rear suspension?
my rear suspension squeaks over sharp bumps, which bushing is the culprit? I will be installing springs/shocks soon and I would like to know which bushings I should replace to cure the squeaking.
Old Jun 11, 2003 | 10:36 AM
jonsteR's Avatar
Default Re: which bushings squeak on my rear suspension? (dc2gsr94)
check your trailing arm bushings and see if it's worn/cut.
btw, you posted a pic of a front suspension
Old Jun 11, 2003 | 10:52 AM
juniordc2's Avatar
Default Re: which bushings squeak on my rear suspension? (jonsteR)
yes, I couldn't find a pic of the rears.. the front picture is actually off of a civic.. it's usualy the trailing arm bushings that squeak? what about the LCA's?
Old Jun 11, 2003 | 11:21 AM
jonsteR's Avatar
from my experience, it's usually the trailing arm bushings that squeaks. This is assuming everything else is stock.
Old Jun 11, 2003 | 12:31 PM
juniordc2's Avatar
thanks for the replies, i'll save up for the mugen ones.. i've read that they don't squeak.
Old Nov 4, 2003 | 05:31 PM
IntEGNYC's Avatar
can anyone suggest an online seller for these bushings? mine are in need of replacing as well. the car is 8 years old so i guess they lasted as long as they have already.
rallyeman
Suspension & Brakes
Feb 26, 2010 07:27 PM
The Internet Tough Guy
Oct 25, 2003 07:47 PM
Oct 25, 2003 11:43 AM
97-TEG-gsr
Jun 4, 2003 03:27 PM
scratchline20
10
Apr 30, 2003 09:00 PM
