Motor swap question
Old Jun 11, 2003 | 10:24 AM
prelude1897's Avatar
Default Motor swap question
A friend of mine is putting an H22a4 motor into his hatch, my question is, what kind of ECU could he use? I know all 5th Gen. Preludes have the imobilzer system, so could he use that ECU, or is there another one that would be better?
Old Jun 11, 2003 | 10:27 AM
DsITR's Avatar
Default Re: Motor swap question (prelude1897)
You probobly already know this..He would most likely use OBDII. But, you can get a harness made, or buy the skunk 2 OBDI conversion.
as far as power/tuning capability..Im not sure what is best, but I would lean towards OBDI for obvious reasons.
This donor motor isn't an SH right?
Old Jun 11, 2003 | 10:31 AM
Default Re: Motor swap question (dsludefosho)
The motor came out of a 2001 Base Prelude. It only has about 9K miles on it, so he got lucky when he bought this motor. I was kind of thinking he should do an OBD I swap. I've never done the swap, so what parts would be needed? I know you need the engine harness and OBD I ecu, is there anything else needed?
Runamok81
Honda Civic (2001 - 2005)
10
May 13, 2020 03:21 PM
ballinsk8er
Jun 7, 2006 02:15 AM
dr juice164
Jul 18, 2004 04:39 PM
prelude1897
Jun 14, 2003 04:22 AM
