integra 40/40 prop valve into an EK
Has anyone installed a integra prop valve into an EK that previously had rear drum? The original prop valve lines are not in the same place as the integras. Do I just have to rebend the lines or is there another way? Is the 99 si prop valve the same as the integras or is it the same as my EK's? Any and all help would be much appreciated.
Thanks
Thanks
do not do it. use the stock valve. if you want to put an integra one in you will have to rebend all but 1 brake lines. that's an estream pain in the ***. so don't wast your time or your brake lines
primojoe20
Oct 22, 2007 02:20 AM
