greasing the shift linkages
Old Jun 11, 2003 | 09:06 AM
Mjfan12's Avatar
Default greasing the shift linkages
what do you use to grease the linkages? And do you just grease from the bottom of the car or inside as well?
Old Jun 11, 2003 | 10:00 AM
Mjfan12's Avatar
bump
Old Jun 11, 2003 | 10:36 AM
Marauder's Avatar
Default Re: (Mjfan12)
On what car?
Most, the only place you would need to is the ball on the shifter and the bushing area where the shifter attaches to the long rod. Use white lithium grease.
Old Jun 11, 2003 | 11:15 AM
Mjfan12's Avatar
on a 94 DX. There is a clicking noise when I shift. The car has many miles on it so I thought it's time to lube it. My friend's manual doesn't make noise.
Old Jun 11, 2003 | 12:57 PM
Sketch_hs's Avatar
where do you put the grease how do you get to it? My car had about 95000 should i do this will it easy up the shifting effort b/c i've noticed it's sometimes a little harder than most cars (not really hard or anything)
Thanks!
Old Jun 11, 2003 | 01:06 PM
Marauder's Avatar
Default Re: (Sketch_hs)
To grease the ball joint on the shifter, you have to get under the car, disconnect it from the arm and pull the shifter out of the car. There is a plastic bushing between the mounting plate and the ball of the shifter....pull the shifter out of the bushing, clean it up, put in new grease and reassemble. If its all stock, you might have to put in new rubber bushings between the shifter and arm.
Vender-
Transmission & Drivetrain
Jan 26, 2013 06:21 PM
chewyv
Jun 8, 2011 08:29 AM
mrbuddha
Jan 28, 2011 12:30 AM
poisonousbeef
Jul 21, 2006 09:20 AM
nijia555
Apr 23, 2003 01:25 PM
