Who makes the shortest steering wheel hub adapter?
Old Jun 11, 2003 | 09:04 AM
migs's Avatar
Default Who makes the shortest steering wheel hub adapter?
Im currently looking for the SHORTEST possible because I have a Signal Auto quick release but dont want it for extension, more rather anti theft purpose.
If I recall, the Momo has a hard metal like cylinder? If thats the case, I can have somebody cut it and reweld it.
The sparco is covered by a rubber boot, and is extended with 3 metal rods inside, which cannot be shortened.
Thanks.
Old Jun 11, 2003 | 01:19 PM
itr98spec's Avatar
Default Re: Who makes the shortest steering wheel hub adapter? (Migs)
i have the same problem, the momo hub is just too long. anyone out there can help?
Old Jun 11, 2003 | 01:59 PM
Big Phat R's Avatar
I think they are designed that way to absorb some impact in case of a front end collision as well as preserve the stock steering wheel location (i.e. distance from turn signal stalks).
I think you may have to end up making one of your own - all I've ever seen is longer hub adapters - not shorter ones.
Old Jun 11, 2003 | 04:39 PM
Tommy_Gunns's Avatar
I believe the momo CRX one (can't think of the number at the moment) will fit the ITR. Not 100% sure, see if you can try it out at a shop.
The CRX momo hub is about half the length of the ITR one.
RGuo921
Sep 16, 2008 09:39 PM
robble36
12
Sep 26, 2007 11:27 AM
citanest
Apr 17, 2002 01:02 PM
