Spoon 70mm Throttle Body
Old Jul 19, 2001 | 09:58 AM
intermugen's Avatar
New User
Default Spoon 70mm Throttle Body
Any one here replace their stock throttle body with a larger one?
Old Jul 19, 2001 | 10:05 AM
MackSpeed-616's Avatar
Default Re: Spoon 70mm Throttle Body (intermugen)
its not a true 70mil
it tapers in to stock bore size
hasnt this been covered?
do a search
peace
Old Jul 19, 2001 | 10:25 AM
Boba-Fett's Avatar
New User
If you change the TB, you should port match the intake manifold to get the absolute maximum gains.
Old Jul 19, 2001 | 10:29 AM
sgT's Avatar
sgT
Default Re: Spoon 70mm Throttle Body (Boba-Fett)
You wont have to port match with the spoon
Old Jul 19, 2001 | 12:42 PM
Leo95SE's Avatar
Default Re: Spoon 70mm Throttle Body (sgT)
goes from 70 to 62mm? quite the psuedo ram air effect...anyone use it? does it work?
does spoon sell an intake to match the intake dia?
Old Jul 19, 2001 | 12:46 PM
FAST94GSR's Avatar
New User
Default Re: Spoon 70mm Throttle Body (Leo95SE)
I'm sure it yields a few hp, but is it worth the price? I doubt it.
Old Jul 19, 2001 | 01:31 PM
Mike M's Avatar
Founding Member
Default Re: Spoon 70mm Throttle Body (FAST94GSR)
It does make a difference, however not a large one If you had a B16 or GSR it is a nice upgrade instead of getting an ITR TB which is more $$$
I'm Going to do a few different dyno tests with the ones I have in stock.
Old Jul 25, 2001 | 05:04 PM
Rhetoric's Avatar
Default Re: Spoon 70mm Throttle Body (TypeRmsm)
Is it possible to bore the Itr throttle body to 67mm straight through?
Old Jul 25, 2001 | 06:58 PM
kenji's Avatar
25 Year Member
Default Re: Spoon 70mm Throttle Body (G S R)
I have not found anybody that can bore the ITR TB to 67mm throughout. The largest diameter that mine was able to be bored to was 65mm. Vernon at RaVer motor sports did a REAL nice job on it. If any body needs to have their TB bored call Vernon at 559-733-4711.
-kenji
Old Jul 25, 2001 | 07:05 PM
FAST4DR's Avatar
Default Re: Spoon 70mm Throttle Body (kenji)
I agree with Mike on this. Biggest gains would be on a b16 with cams. I have not tested on an ITR with cams, though and would like to do so. Any takers? I have one of these sitting around. Actually, the price is about what you would pay for a STOCK ITR TB, so its not a bad deal. Contact me if you want to guinea pig this. Of course for doing so, you would get a deal, too. Thanks!
Weel
Mar 9, 2006 08:06 PM
Coupe-R
Feb 14, 2006 06:04 PM
93jdmr
Jan 19, 2004 01:31 PM
EGsex
Dec 10, 2002 03:49 PM
HYBRIDHATCH92
Apr 3, 2002 11:19 AM
