Got Pix?? Rear lower tie Bars
Old Jun 10, 2003 | 03:19 PM
AlphaQup's Avatar
Default Got Pix?? Rear lower tie Bars
anybody got pix of their rear lower tie bars. I'm debating one which brand to get but not sure what options are out there. dont be shy... post up an *** shot
Old Jun 10, 2003 | 04:46 PM
ntrinsik's Avatar
Default Re: Got Pix?? Rear lower tie Bars (AlphaQup)
Mine.. but it's not a standalone tie-bar.. :\
Old Jun 10, 2003 | 05:01 PM
Denis Si's Avatar
Default Re: Got Pix?? Rear lower tie Bars (ntrinsik)
Skunk2
Old Jun 10, 2003 | 05:04 PM
Bigphlip's Avatar
Default Re: Got Pix?? Rear lower tie Bars (Denis Si)
Where did you get those LCA's? How much? Do they really help?
Old Jun 10, 2003 | 05:11 PM
Bumnah's Avatar
Default Re: Got Pix?? Rear lower tie Bars (Bigphlip)
Old Jun 10, 2003 | 05:45 PM
Denis Si's Avatar
Well my rear used to squeak , not any more, plus the reason why i replaced them is becuz when i was doing read disk conversion, my OEM lcas ceased
Old Jun 10, 2003 | 05:51 PM
Bigphlip's Avatar
Where can I get a set of those? and how much will they run me?
Old Jun 10, 2003 | 06:00 PM
nerdsports's Avatar
Default Re: Got Pix?? Rear lower tie Bars (Bumnah)
BUMNAH: did u have to do anything 'custom' or different [compared to others] to mount that tie w/ the suspension techniques bar? [is that an ST bar?].... i got the same one and it looks as if no tie bar will fit.
Old Jun 10, 2003 | 06:38 PM
Bumnah's Avatar
Default Re: Got Pix?? Rear lower tie Bars (nerdsports)
the rear sway bar is a 22mm ITR rear sway bar.
Will at Beaks products sold me a spacer and new LCA bolts for the benen rear lower tie bar. The bar sits on top of the spacers to clear the beaks kit/itr rear sway bar.
Great combo. One of my best mods.
Old Jun 10, 2003 | 07:42 PM
ek_will's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Denis Si &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2
howd u get that bar in? bolts wouldnt go threw for me so i got tired any trick to it or just patience?
Old Jun 10, 2003 | 08:44 PM
KOALA YUMMIES's Avatar
Default Re: Got Pix?? Rear lower tie Bars (dash0n)
Take the wheels off, put a jack under the LCA and raise or lower the jack to get the holes to line up. Thread one bolt in then do the next. Use lots and lots of penetrating oil.
Old Jun 10, 2003 | 08:51 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: Got Pix?? Rear lower tie Bars (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">Take the wheels off, put a jack under the LCA and raise or lower the jack to get the holes to line up. Thread one bolt in then do the next. Use lots and lots of penetrating oil.</TD></TR></TABLE>
I just prop my legs against the tire to keep the LCA from moving once I get it lined up.
It's not hard, the bolts are pointed.
Old Jun 10, 2003 | 09:16 PM
Default Re: Got Pix?? Rear lower tie Bars (SkyeC)
The bolts arent tapered for the Skunk2 bars, that's why.
Old Jun 10, 2003 | 11:06 PM
ntrinsik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">The bolts arent tapered for the Skunk2 bars, that's why. </TD></TR></TABLE>
The bolts aren't tapered for the S/T rear combo either.. was a bitch to install!
Old Jun 12, 2003 | 08:19 PM
ek_will's Avatar
sure is a bitch to install. hopefully i can get it in next time i get to work on my suspesion still waitin for my tokico shocks, i got a ceased LCA too how much those ones you have cost?
rallyeguy
Jul 31, 2004 10:15 AM
RUBZERK
Mar 25, 2004 10:00 AM
nakashima79
Mar 20, 2002 09:52 AM
spoon805
Jul 31, 2001 07:36 AM
