B16 question......
Is it just my engine or does everybody's B16 leak oil where the head meets the block right above the "B16A" stamp? Cause i've checked out a few B16 swaps and they were all leaking oil in that same location.
it might be that cam seal seal on the head(black circle -plastic) its above where you said theres oil.... it leaked down to that area on mine. i bought a str cam seal and have zero problems now.
I know exactly what you guys are talking about but the oil comes from where the head mates w/ the block. Could it be that the head needs to be bolted on a little tighter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyosupr »</TD></TR><TR><TD CLASS="quote">it might be that cam seal seal on the head(black circle -plastic) its above where you said theres oil.... it leaked down to that area on mine. i bought a str cam seal and have zero problems now.</TD></TR></TABLE>
I did the same thing and it solved my problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brandon Chun »</TD></TR><TR><TD CLASS="quote">I did the same thing as those guys and on my Teg too. Wonder if it is a common Honda problem..</TD></TR></TABLE> Yes it is because it's plastic.
THC07
13
Feb 14, 2007 06:39 PM
Spikes11
Mar 20, 2004 10:34 PM
