JDM 4-1 Header install questions - what is needed?
Old Jun 10, 2003 | 01:44 PM
spd18's Avatar
Default JDM 4-1 Header install questions - what is needed?
(i have a GSR, but i figured you guys here know more about this header. also, i already searched and couldnt find the answers i was looking for)
i recently got my jdm 4-1 header, and today i just bought a 2.5" carsound cat from mike at IPS (should be here next week). now my question is, what all do i need for this install? the header didn't come with anything (no gaskets or anything like that). will the cat come with the gaskets that i need? also, while searching i read about some stuff about the bracket the header bolts on to.. will this header bolt up to the bracket (i didnt get any special bracket with the header..)? or do i even need to use the bracket with this header if it doenst fit? anything else you can suggest? im not too worried about the install, i just want to be sure i have everything i need, thats why i want to know about the gaskets and brackets and such.
Old Jun 10, 2003 | 04:26 PM
Aaron M's Avatar
Default Re: JDM 4-1 Header install questions - what is needed? (spd18)
you'll need an s2000 header collector gasket
Old Jun 10, 2003 | 05:21 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: JDM 4-1 Header install questions - what is needed? (SilverB18C1)
http://www.itr-nc.com/pages/jdm_4.htm
Old Jun 10, 2003 | 08:12 PM
B2FiNiTY's Avatar
You will need some longer bolts too.
Old Jun 10, 2003 | 08:15 PM
skafia's Avatar
25 Year Member
Default Re: JDM 4-1 Header install questions - what is needed? (B2FiNiTY)
It is suggested that your replace the exhaust manifold gasket with a newer one.
The bolts on your stock cat are going to be a bitch to remove. Get some liquid wrench on there and it'll be easy.
You don't need to use a header bracket.
Old Jun 10, 2003 | 08:20 PM
spd18's Avatar
Default Re: JDM 4-1 Header install questions - what is needed? (skafia)
i did a search and read about someone here installing a toda header, and they said that you dont need to use the bracket for that. but isnt the JDM ITR header heavier? are you sure you dont need to use the bracket on it?
Old Jun 11, 2003 | 06:16 PM
spd18's Avatar
okay, couple more questions to clarify:
1) what are these longer bolts used, or required, for? what did everyone use, or what do i buy (and from where)?
2) what is the part number for the exhaust manifold gasket?
3) what is a good place to buy this and the s2k collector gasket from?
4) it is infact safe to not use the header bracket for the new header, correct?
Old Jun 11, 2003 | 06:26 PM
Splat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spd18 &raquo;</TD></TR><TR><TD CLASS="quote">1) what are these longer bolts used, or required, for? what did everyone use, or what do i buy (and from where)?
4) it is infact safe to not use the header bracket for the new header, correct?</TD></TR></TABLE>
1) Whichever bolts have the springs on them. Collector-to-cat, I guess.
2) How many miles on your car? Below 30k-ish, I would not bother replacing it.
3) Manifold gasket = dealer. Donut = read the link I posted
4) You do not need the header bracket.
Old Jun 11, 2003 | 07:09 PM
.RJ's Avatar
.RJ
Default Re: JDM 4-1 Header install questions - what is needed? (Splat)
what about the gasket on the backside of the cat? the little metal cockring... i assume the one for the stock cat doesnt fit?
Old Jun 11, 2003 | 09:05 PM
Splat's Avatar
Default Re: JDM 4-1 Header install questions - what is needed? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">what about the gasket on the backside of the cat? the little metal cockring... i assume the one for the stock cat doesnt fit?</TD></TR></TABLE>
The cat to b-pipe connection? JDM 4-1 needs an 2.5" in/out cat, which won't mate to the stock b-pipe anyway. I drove mine open-header to a muffler shop and had that welded to fit. I think Dave (SMSP) sells a full bolt-up solution, but I'm not sure.
Old Jun 11, 2003 | 09:23 PM
GettaluvR's Avatar
New User
hmmm
how about my problem ?
thinking of getting new toda header and used USDM mugen exhuast, what kinda cat do i need ? since toda is 2.5 and mugen just same as stock ! and does toda header come with bolts ? or i have to get them ?
Old Jun 12, 2003 | 04:21 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">The cat to b-pipe connection</TD></TR></TABLE>
Yep... that one... the metal ring (not donut)
Old Jun 12, 2003 | 05:08 AM
Splat's Avatar
Yep... that one... the metal ring (not donut)</TD></TR></TABLE>
The muffler shop I went to provided that piece. He cut the stock b-pipe and welded an adapter in place to remove the restriction. Again, Dave @ SMS sells a nice piece to take care of this problem.
If you have a 2.5" b-pipe, gaskets should be easy to find, unlike a (cheap) gasket that fits the collector-cat connection.
Old Jun 12, 2003 | 05:33 AM
Asahi's Avatar
The cat will bolt to a stock exhaust. The gasket in question can be found at Autozone made by Mr Gasket.
Old Jun 12, 2003 | 08:05 AM
spd18's Avatar
where do you get the longer bolts to use for this?
Old Jun 12, 2003 | 08:12 AM
SlapSmak's Avatar
Dave (SMSP) has all this, IM him and i am sure he will hook you up.
Old Jun 12, 2003 | 09:26 AM
387's Avatar
387
Default Re: JDM 4-1 Header install questions - what is needed? (SlapSmak)
I have an Apexi N1 exhaust. Will the 2.5 outlet of the cat bolt up to it? Do I use the S2000 gasket from the cat outlet to exhaust inlet also or just get any that they have at the muffler shop.
Old Jun 12, 2003 | 10:38 AM
Asahi's Avatar
Default Re: JDM 4-1 Header install questions - what is needed? (387)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 387 &raquo;</TD></TR><TR><TD CLASS="quote">I have an Apexi N1 exhaust. Will the 2.5 outlet of the cat bolt up to it? Do I use the S2000 gasket from the cat outlet to exhaust inlet also or just get any that they have at the muffler shop.</TD></TR></TABLE>
It will bolt to the exhaust assuming you bought the right custom length cat.
Here is how this works
Header -&gt; S2000 Donut Gasket -&gt; Cat -&gt; Autozone 2.5" 3 hole gasket -&gt; B-pipe (Exhaust)
(Longer bolts and washers for springs)
Old Jun 12, 2003 | 10:45 AM
Splat's Avatar
where do you get the longer bolts to use for this?</TD></TR></TABLE>
Bolts R Us
Any Lowe's Depot type store will have what you need. Take an old one with you, and just get one a couple inches longer.
Old Jun 12, 2003 | 10:56 AM
Seedc2's Avatar
why is the s2k donut gasket used? how much does it cost
Old Jun 12, 2003 | 11:27 AM
Asahi's Avatar
Default Re: (kendogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kendogg &raquo;</TD></TR><TR><TD CLASS="quote">why is the s2k donut gasket used? how much does it cost</TD></TR></TABLE>
It is used because the stock one is 2.25" and the JDM header is 2.5" just like the S2k.
Old Jun 12, 2003 | 12:28 PM
underrated99si's Avatar
Default Re: (Asahi)
Contact SMSP he supplies the cat gasket and all the hardware and it will match up to what ever cat back u run great guy good product and great service
RCautoworks
Mar 11, 2003 10:08 AM
onyx00
Jul 2, 2002 10:27 PM
lilcasino
Apr 17, 2002 01:03 PM
1fastGSR
Oct 8, 2001 06:33 PM
onyx00
Aug 18, 2001 07:20 PM
